Author Topic: Loose drive sprocket  (Read 502 times)
Offline mattsz
« on: July 20, 2020, 03:45:36 PM »
My searches reveal that sometimes, some SOHC bikes have a loose-fitting front sprocket.  My 400's was a bit loose, and the replacement I bought is just the same - a bit of sideways wobble and the tiniest bit of rotational play on the shaft, without the "sprocket fixing plate" installed.
Assuming that's ok... when installing the new one, any lubrication or other protections recommended?
Offline ka-ja
  • ken
  • yoshi 460
Re: Loose drive sprocket
« Reply #1 on: July 20, 2020, 04:51:20 PM »
Yes, they all all slack to some degree, mines been loose since 1980.
nice bike,nothing in the bank
« Reply #2 on: July 20, 2020, 05:07:27 PM »
I grease the splines to reduce wear and stop the rust like you had. ☺
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #3 on: July 20, 2020, 05:12:54 PM »
Yes I noticed that but on mine once the fixing plate is done up it was solid.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline mattsz
« Reply #4 on: July 20, 2020, 05:43:22 PM »
Thanks guys!
