Author Topic: My new helping hand...  (Read 2398 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: July 22, 2020, 01:06:45 PM »
For too long have struggled with trying to innovate when trying to remove rear wheels / front forks etc. Last weekend thought, “enough!”, whipped down to Bunnings and bought an electric hoist (250Kg).
It’s now installed in the garage ceiling (against a triple joist) and suddenly my life has become a whole lot easier.
Bliss...
Online Moorey
Re: My new helping hand...
« Reply #1 on: July 22, 2020, 02:11:24 PM »
I just have 4 ratchet straps hanging from the roof.  2 front and 2 rear so i can lift either end or the whole bike if needed.  Cheap as chips.
Offline Andrew-S
« Reply #2 on: July 22, 2020, 02:31:06 PM »
No centre stand on the Guzzi?
Never had a problem getting the rear wheel off my CB750 or Z900 on the centre stand, the forks are a different matter and you can't do both at the same time safely using just the centre stand ::)  ;D - I've seen members jacking up the front using a car jack and axle stands or timber to support it to get the forks off and on, but I've found using a front paddock stand quick and convenient:
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
« Reply #3 on: July 22, 2020, 04:09:58 PM »
I nearly pulled my garage down, lifting my CB750 engine like that :)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: July 22, 2020, 11:44:13 PM »
Yup, no centre stand on the Guzzi.... don’t reckon I’d be strong enough to use it if it had one given the CB750 taxes me these days...
All comments valid; the truth is I can’t help myself when it comes to tinkering, but I can indeed see this hoist being used. Certainly I won’t be lifting full bikes.... I reckon I’ll limit it to 150Kg given this is what I’ve just done.... with zero creaking or dramas.
My other garage helper is Socket the cat, who uncannily found a safer vantage point for this project...
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: July 23, 2020, 09:51:13 AM »
... summat to do with witnessing 10 yrs of my DIY I guess 😂
« Reply #6 on: July 23, 2020, 10:21:17 AM »
Nah ken that is the "Who is going to feed me when he is in hospital again" look
Offline cooleronthecoast
« Reply #7 on: July 23, 2020, 08:36:15 PM »
£25 at a garage sale.    ;)
Now where did I put that 10mm socket?
Offline Green1
« Reply #8 on: July 23, 2020, 09:41:25 PM »
Blimy you could almost lift a Guzzi with that
I prefer a different approch with my Guzzi. It gives you a hernia so it sits on the bench for a week before you touch it again.
For some reson my garage has a ramp in front of the door.
So I take a run up from the start of the drive up the ramp.
Just as the rear wheel hits the ramp to the garage the front wheel hits another ramp for the bench. So the bike clibs 2 feet in about half the bikes length. Not easy as the handle bars end up about ear hight.
The good thing with the Guzzi is it has a flat sump pan so easy to jack up with a car jack.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #9 on: July 23, 2020, 10:05:03 PM »
I would want the h beam or i beam in the 25
Online Moorey
« Reply #10 on: July 23, 2020, 10:15:48 PM »
If that  happens I only have my self to blame as I built the garage. ;)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #11 on: July 24, 2020, 12:58:16 AM »
Bloody hell Mick, that sounds fraught... given these rhinoceroses weigh 240Kg or so.
(tried the sump pan lift, but given the heaving and pulling on getting out the swing arm decided better of it)
My Bunnings winch set me back £110 (A$199) which I thought a steal. This said, it’s made in China, ..... which in hindsight perhaps explains the cat?
« Reply #12 on: July 24, 2020, 08:16:51 AM »
What a cool cat,  even improvised it's own covid screen too. They always know more than they let on.
Little known but cats are calibrated,  they're good for weights,  torque and amps. Not so hot on voltage,  where you'd be better using a wire haired terrier.
 ;D ;D ;D
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #13 on: July 24, 2020, 09:14:42 AM »
This with locking straps worked for the front wheel and forks off!
(I think I took the mirrors off so the bars could go through the ladder)
« Last Edit: July 24, 2020, 12:58:19 PM by jeremypeachey »
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
« Reply #14 on: July 24, 2020, 11:22:03 AM »
That's a great idea, cheap and doesn't take up workshop space 👍
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
