Author Topic: Throttle movement amount  (Read 1239 times)
Offline bobv7
Re: Throttle movement amount
« Reply #15 on: August 01, 2020, 08:23:04 PM »
Yep, 90 degrees is right for the 500 too.
Offline bobv7
« Reply #16 on: August 05, 2020, 02:16:49 PM »
I've bought a new throttle pipe off eBay that says it it fits a wide range of classic Honda models. It fitted OK and the lead lift of the ramp looks a bit longer than the old one. It did feel a bit better to me although it's still 90 degrees closed to open.
https://www.ebay.co.uk/itm/Honda-Push-Pull-Throttle-Tube-AND-GRIPS-53141-300-010-CB-350F-400F-550-CX500/303243856707?hash=item469abe0b43:g:~qoAAOSwAqhdnNIL
Offline robvangulik
  • Honda Fourever
« Reply #17 on: August 05, 2020, 02:43:16 PM »
I think you shouldn't want to have much less, it will be harder to (hold) open and also harder to dose the throttle, long ago I tried speed gas on my 750 for a while, but went back to standard after a couple of months. That was mainly useful to ride full speed all the time, and doing that on the street, well you know......
