Author Topic: points cover gasket adhesive  (Read 462 times)
Offline mattsz
« on: August 03, 2020, 02:29:38 PM »
My points cover gasket is no good.  I have a replacement, the same thin cork ring as original.  It definitely needs to be secured in place... any specific adhesives to use or avoid in this application?
Re: points cover gasket adhesive
« Reply #1 on: August 03, 2020, 03:02:22 PM »
You don't need to use any adhesive of any type Matt.
Offline mattsz
« Reply #2 on: August 03, 2020, 03:05:12 PM »
Ah, well the old knackered one is glued in, so I just assumed.  Plus, my new one is an NOS gasket that has taken a slightly out-of-round shape and won't stay in place when I try to close up the cover...
Offline bobv7
« Reply #3 on: August 03, 2020, 03:08:23 PM »
Because the gasket doesn't have any screw locating tabs and it wouldn't stay put I binned it and put a thin bead of black RTV silicon around the edge of the cover.
Offline mattsz
« Reply #4 on: August 03, 2020, 08:49:04 PM »
Well, it's academic - the gasket doesn't fit regardless.  It's presumably NOS genuine Honda cork - I don't know if it shrinks over time, but its diameter is not really even close to being large enough to seal the cover.
I'm working on a refund - I think I'll just make my own...
