Author Topic: Wiring Loom routing on CB400F2 & best replacement source.  (Read 1236 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
Re: Wiring Loom routing on CB400F2 & best replacement source.
« Reply #15 on: August 29, 2020, 06:35:22 PM »
Is this "speed unit" some kind of warning device?  I see lots of references to the bracket, but not much on the device itself.
I must admit to being a bit skeptical about the notion that the loom "rubber band" is meant to hook on the speed stay bracket, even though that's the way mine came to me.  It's a pretty awkward fit; the angle isn't right for either end of the strap:
(Attachment Link)
There's a bottom tab on the frame which seems to be designed to receive the lower end of the strap; I don't have a photo of it but when utilized, the strap lines up much better with its upper tab:
(Attachment Link)
I came across this SB today; I’ve had it all along :-[
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
