Author Topic: Parts availability  (Read 1026 times)
Re: Parts availability
« Reply #15 on: August 15, 2020, 09:06:52 AM »
Offline Gromitdog
« Reply #16 on: August 15, 2020, 09:21:33 AM »
Hi Phil
I found a seller on eBay that is selling S/Steel seat hing pins if you buy another item like carb overflow rubber tubes postage is free.
I have extensively searched for speedo & Rev counter parts its very difficult to work out which route to take I need just the joining bands see CB750faces they are eye wateringly expensive then you got P&P  on top :'( :'(.
You may find that people in the USA have a better selection but as Graham & Julie say you got P&P plus Boris's cut to add on.
Graham & Julie & Ken and everyone else here have helped and guided me through what can and can not be used to return a bike back to a good standard ( Thanks you  :) :) )
Here are a couple of links that may help you with your project
www.CB750faces.com
https://www.ebay.co.uk/i/293602758201?ul_noapp=true
Best Regards
Nigel
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
« Reply #17 on: August 15, 2020, 09:22:55 AM »
Cheers Graham, I'll have a good look at those - mine are similar with slight creases in. Based are your feedback the main thing is I've established I can get replica guard and clock backs and will have to refurb headlight brackets.
As I've said before, I prefer the k0/k1 clocks and headlight setup but hey, I've bought the K2 now
Am enjoying basic standard rebuild though compared to having to modify everything as I go along as per last 2 projects (K6 cafe & CR Rep)
Sent from my Moto G (5) using Tapatalk
« Reply #18 on: August 15, 2020, 09:31:12 AM »
Hi Phil
www.CB750faces.com
Best Regards
Nigel
I've already bought them Nigel! and have the tubes on watch! Used the 750faces for my 750k2.
I've got the K6 cafe racer for sale at moment and when sold, there'll be a mass parts order going in to DS/CMSL! (I have bought the exhausts already)
Thanks for heads up anyway
