Author Topic: Testing a 750 Retifier  (Read 432 times)
« on: August 16, 2020, 08:36:49 PM »
I've been in the shed and come across a spare rectifier (not a regulator rectifier) and was wondering how to test it off the bike? I understand the principle of the diodes letting current through only one way but not how you physically test the unit.
Any guidance much appreciated
Re: Testing a 750 Retifier
« Reply #1 on: August 16, 2020, 09:06:43 PM »
Establish which is positive of the rectifier and which is negative.
Using a multimeter on the diode range (or ohms range if there's no diode range)
Put the red meter lead on the negative and test each yellow lead of the rectifier in turn.  Then do the same tests with the black meter lead on the negative.
You should have a reading on all 3 in one direction but no reading the other direction.
Now put the black lead on the positive,  check all 3 yellows .
Do same with the red lead on the positive.
As before,  a reading in one direction but nowt the other direction.
Hope this helps.
« Reply #2 on: August 16, 2020, 09:25:55 PM »
Cheers Mike, I'll have a go over the next few days
