Author Topic: Brake Caliper Paint  (Read 1345 times)
Brake Caliper Paint
« on: August 18, 2020, 08:46:00 PM »
I'm just refurbing the front brake caliper on the 500k2 - I have always used Simonize Satin black but thought I'd ask what other members use? Is there any spray paint that is brake fluid resistant?
Re: Brake Caliper Paint
« Reply #1 on: August 18, 2020, 08:58:38 PM »
How about VHT Brake Caliper Paint Phil.
https://www.vhtpaint.com/high-heat/vht-caliper-paint
« Reply #2 on: August 18, 2020, 09:08:06 PM »
👍+1 on that Julie, it's good paint and I've never had any problems with it.
I always get the calipers bead blasted (not vapour blast). The bead blasting prepares the casting and gives it a rough surface for the paint to adhere to. The calipers are also quite an intricate casting and blasting gets rid of the old paint and muck from all the nooks and crannies.
Just make sure the first coat is a dusting, don't be tempted to spray it in one go. I usually apply four coats.
One can is good to paint four calipers.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #3 on: August 18, 2020, 09:39:21 PM »
Thanks guys, I'll give it a go
« Reply #4 on: August 19, 2020, 09:20:38 AM »
Julie's spot on with the VHT, did mine in 2007 and they still look good today
Online ST1100
« Reply #5 on: May 12, 2021, 07:29:58 PM »
STOC #637
« Reply #6 on: May 12, 2021, 08:28:04 PM »
Any primer required?
Not with what we use but read the instructions on the can.
« Reply #7 on: May 12, 2021, 08:29:09 PM »
Not with what we use, all depends on the prep though, refer to the instructions on the tin 😁
