Author Topic: 750 f2 gearing  (Read 1128 times)
Offline sohc bob
750 f2 gearing
« on: August 22, 2020, 03:05:05 PM »
Hi all,
After recently aquiring a 1977 cb750f2 im over the moon with it, yes it has a few things i want to do to it but over all it starts on the button and idles once warm, however when riding it seems to take ages to gain decent speed both rev counter and speedo seem to climb slowly, im beginning to think it may be over geared, the bike rolls freely and brakes dont bind. Rear sprocket is 43 teeth not sure about front still need to remove the cover, speed wise in 5th gear its doing 60 at 4k, 75 at 5k and 90 at 6k is this right any advice will be greatly appreciated, thanks in advance
Bob
« Last Edit: August 22, 2020, 03:11:18 PM by sohc bob »
Re: 750 f2 gearing
« Reply #1 on: August 22, 2020, 03:45:10 PM »
That looks about Ok.
The motor needs revving.
Offline sohc bob
Re: 750 f2 gearing
« Reply #2 on: August 22, 2020, 04:18:19 PM »
With the throttle wide open it just seems so slow to rev
Re: 750 f2 gearing
« Reply #3 on: August 22, 2020, 04:37:08 PM »
If you want spirited riding. Keep the revs above 6k, and don't change till above 8k.
If it still feels sluggish. Check timing and mixture
Offline sohc bob
Re: 750 f2 gearing
« Reply #4 on: August 22, 2020, 05:15:01 PM »
Points gap in spec and timing spot on bike idles evenly with no issues through rev range so im guessing carburation is pretty good or am i expecting too much im not after masses of speed but it feels muted ii has a motad 4/1 plugs are new as are caps and air filter
Re: 750 f2 gearing
« Reply #5 on: August 22, 2020, 06:56:11 PM »
The bike is nearly 50yrs old.
Will it run to 8k in 4th?
Offline sohc bob
Re: 750 f2 gearing
« Reply #6 on: August 22, 2020, 07:30:49 PM »
it will hit 8K in fourth if you wait long enough, ive checked the sprockets and it has 15/43 does anyone know if this is correct
Online Bryanj
Re: 750 f2 gearing
« Reply #7 on: August 22, 2020, 08:13:20 PM »
Check the parts book it will tell you
Online SumpMagnet
Re: 750 f2 gearing
« Reply #8 on: August 22, 2020, 08:45:14 PM »
checked mine...43T rear sprocket is what I have...so I reckon that is right. Same with the 15T gearbox sprocket.
Judging also by your speeds in gears...if you are pulling 90mph at 6000rpm in top, that sounds right to me. You are not going to see much over 110 unless you are flat on the tank. Maybe you could hit the dizzy heights of 120mph if you try hard.
You would need to hold the revs in each gear, though, or be prepared to wait. These bikes don;t have anything like the power of a modern 750
CB750F2 - in pieces
Offline sohc bob
Re: 750 f2 gearing
« Reply #9 on: August 22, 2020, 10:15:26 PM »
Thanks for the replys maybe I am expecting too much from it I had a 77 f2 4 years ago and don't recall it being like this plus maybe I've been spoilt by modern bikes although I am suprised that I can run at 2500 rpm in top and open the throttle and she picks up with no hesitation seems to be quite torquey low down
Re: 750 f2 gearing
« Reply #10 on: August 23, 2020, 08:31:45 AM »
Speeds in the gears are about the same as mine so would suggest the gearing is correct. Mine picks up very quickly but you need to drop gears and rev the thing. If you try to accelerate in 5th gear it is very sluggish. You didn't mention what gears and revs you were using.
On these old bikes it can often be too much mechanical sympathy causing the issue, give it some beans, the old girls love it.
On the carb issue, poor pick up could be a stuck accelerator pump or ruptured diaphragm.
Online Bryanj
Re: 750 f2 gearing
« Reply #11 on: August 23, 2020, 08:45:35 AM »
Back in the 70's took an 18 month old 28000 mile F2 to the IOM TT, wouldnt go over 95, smoked like a pig and dropped to 150 mpp of oil.
First one i came accross with the worn out exhaust valve guides.
The F2 cam was different and may have been changed in your bikes life and if its not had exhaust guides it will need them-----they ALL did and it was not done as a recall or under warantee unless the problem occured in the first 12 months
Re: 750 f2 gearing
« Reply #12 on: August 23, 2020, 05:00:47 PM »
There's a fix for the top end problems from CycleX in the States involving hardened guides, supposed to be a permanent fix. I hope it is as that's the fix I used on my F2. If anybody needs it this is the link   http://www.cyclexchange.net/Honda%20cb750%20(%2077-78%20)%20%20F%202%20Section%20Page.htm
Online Bryanj
Re: 750 f2 gearing
« Reply #13 on: August 23, 2020, 05:31:37 PM »
The replacement parts from Honda were extremely hard
Re: 750 f2 gearing
« Reply #14 on: August 23, 2020, 05:50:52 PM »
The CycleX Kibblewhite parts are also longer to better support the valve and a more modern material. They reckon to have had an engine to 60k without any issues at all from the exhaust valves.
