Author Topic: 750 f2 gearing  (Read 1089 times)
Offline sohc bob
Re: 750 f2 gearing
« Reply #15 on: August 23, 2020, 07:17:39 PM »
Hi the bike burns no oil and does not smoke i have canned the knackers of it only a couple of times at full throttle in all gears and yes in the lower gears it accelerates better as you would expect and i only did this to try its not my intention to thrash it but as ive said all along i just thought it would rev quicker than it does i may try a 14 tooth frnt sprocket anyone tried this opinions please
Re: 750 f2 gearing
« Reply #16 on: August 23, 2020, 08:20:23 PM »
Too small for the chain, if you must alter the gearing alter the rear sprocket but not sure its worth it, admittedley Honda only spent 100's of 1000 developing this model but they normally got it right
Offline robvangulik
  • Honda Fourever
Re: 750 f2 gearing
« Reply #17 on: August 23, 2020, 09:10:41 PM »
The 630 chain wasn't the ultimate solution though ;D
The 14 tooth sprocket was used by Honda on some models, so it can't have been too bad. And I have seen a 15/41 drive quoted too.
