Author Topic: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.  (Read 48635 times)
Re: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.
« Reply #90 on: November 04, 2020, 10:39:27 AM »
This is my left side part engine cover that hides the starter motor and front chainwheel gear etc.
before by Teddy Bagshaw, on Flickr
This is the paint finish after stripping and rubbing down with 1200 grit. Just needs oven baking tomorrow when I can use the oven more freely if you get my drift.
 after by Teddy Bagshaw, on Flickr
« Reply #91 on: November 04, 2020, 03:32:13 PM »
Looking good. Best of luck with the bake-off. 👍
Offline THUNDERDOWNUNDER
« Reply #92 on: November 07, 2020, 07:28:12 AM »
Hi , have you got a picture of the underside of side cover where the electrics are ? My 75 400/4  doesn’t want to close so just need pic to see what’s the right and wrong way to wire up things . Thanks if you can .
« Reply #93 on: November 07, 2020, 10:20:42 AM »
No but I will take one later today and post it.
Offline Deano400
« Reply #94 on: November 07, 2020, 10:31:34 AM »
Do you mean this?
« Reply #95 on: November 07, 2020, 11:24:09 AM »
Does this help ?
IMG_20201107_111052 by Teddy Bagshaw, on Flickr
« Reply #96 on: November 09, 2020, 12:30:44 PM »
Bit of an update on the project.
When I first started the engine after it's 12 year rest it started pretty easily this has in part led me to believe that maybe an engine strip down was not needed. (Clearly in denial here)
Since that first start up it has taken a lot of more cranking to get her to fire up - this has led me to suspect that the compressions are not that brilliant. A cold check on 25th Sept 2020 revealed that the compressions were a pretty even 90 psi on all cylinders rising to 110 psi when check some days later.
Yesterday I just could not get the engine to start so this morning I squirted some 2T oil in all four cylinders with a view to re-checking both cold and hot compressions. The first thing I noticed was that when I cranked the engine about an hour later without the plugs in place almost no oil was pushed out so it had obviously drained through the piston rings I am thinking. Another cold check then revealed 205 psi on cylinder 4 I didn't bother check any others I knew the truth already.
When I replaced the plugs the engine fired up fairly easily so I let her run until up to temperature then did a hot check on cylinder 4 - it was only 120 psi. Clearly I am loosing compression with the rings / pistons being the main culprit.
Obviously I will need to carry out an engine strip as the compressions are well below par. Just as a point in case the engine does run quite nicely in the circumstances especially considering that I have not adjusted any idle air screws.
I now intend to crack on with the strip down of the frame ASAP hopefully I will get the engine out before my operation that still has no date due in part to the effects of Covid on ICU bed availability.
Just for the craic I have recorded some engine running earlier today to keep me enthusiastic I will post a link shortly.
https://youtu.be/SWwb3LgNpIY
« Last Edit: November 09, 2020, 12:50:11 PM by Macabethiele »
« Reply #97 on: November 09, 2020, 12:54:20 PM »
Could not resist a bit of revving - smoke is a mixture of 2T oil burn off and hot oil spilt on the engine. It will be next year now before she runs again (hopefully).
https://youtu.be/3CpAYjNHggI
Offline smoothoperator
« Reply #98 on: November 09, 2020, 05:40:44 PM »
Are you sure about the 205 psi on No 4 Ted. I know what you mean about a successful engine run making you overly optimistic. Had my engine running 3 times now and started to think I'll leave the carbs alone it's running great. Last run petrol was pissing out from No4 overflow pipe. However I didn't use your bike rocking technique on this occasion. Anyways clearly the carbs WILL need attention. Good luck with the fun part of moving from fiddling about to taking to bits!
Steve
2017 Triumph Bonneville T100
« Reply #99 on: November 09, 2020, 07:58:22 PM »
Clearly the 205 psi reading is unlikely to be accurate. The gauge was less than £12 so it's a relative rather than absolute.
« Reply #100 on: November 10, 2020, 08:28:57 PM »
I've substantially stripped down the frame so I can remove the engine hopefully on Friday when my younger brother (by 10 yrs) can help lift it out.
The sump pan had some rusty grey deposit in the bottom with an odd little pipe on the oil pick up strainer - not sure what that does though.
frame part strip down by Teddy Bagshaw, on Flickr
sump pan by Teddy Bagshaw, on Flickr
« Reply #101 on: November 10, 2020, 08:35:16 PM »
If you look up into the bottom of the engine you'll see a spigot that the "funny little pipe" pushes onto.
Part of the oil circulation system.
« Reply #102 on: November 10, 2020, 08:48:28 PM »
Yeah noticed that little pipe I've no idea what it actually  does it fits into the strainer.sump strainer by Teddy Bagshaw, on Flickr
« Reply #103 on: November 10, 2020, 11:23:21 PM »
Gearbox oil pump on end of one of the shafts
« Reply #104 on: November 11, 2020, 08:38:03 AM »
Great progress Ted, somebody has been busy. Good luck getting the engine out.
Steve
