Author Topic: '77 CB400F - it runs!  (Read 2181 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
Re: '77 CB400F - it runs!
« Reply #15 on: September 03, 2020, 03:25:38 PM »
I’m jealous; you are where I want to be, without the cam chain problem of course. Well done.
I read somewhere that it is possible to “fix” a non-functioning adjuster by, essentially, doing just what you said.
You plug off the adjuster bolt and use a longer bolt with a locknut in the oil cap channel to push down on top of the adjuster rod until the noise goes away. The tighten up the locknut.
So I guess it wold be safe enough to try. It won’t work if the horseshoe is seized or if the chain is over-stretched, as Julie says, I suppose, but it might work if the horseshoe is just a bit sticky.
Oh and no, I didn’t try it. I fixed the adjuster bolt etc.
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
« Reply #16 on: September 03, 2020, 03:49:23 PM »
Gareth,
Looks familiar!!!
When I finally got the 400 running the other week I was so keen to just sit on it I forgot that wearing shorts isn't a great idea near a piping hot exhaust - nice burn to remind me next time!
Cheers,
Andy
Ouchy! Stings doesn't it. 😯
Offline mattsz
« Reply #17 on: September 03, 2020, 04:06:21 PM »
Certainly worth a try... to that end, I took a chance and ordered this "manual cam chain adjuster" bolt, made by our friend Kevin from TTR400.  It basically does the job you describe above, and is much more controllable than just inserting some kind of rod down into the opening and just pushing by hand.  As long as I can maneuver my tools in between the header pipes and frame openings...
Worst that can happen, I guess, is that it won't work and I'm out $20.  Or is it?  ;)  At least it will help me diagnose the issue...
« Reply #18 on: September 03, 2020, 04:37:30 PM »
That is not good! OUCH!
1978 Honda CB550K3.
Offline mattsz
« Reply #19 on: September 04, 2020, 08:35:29 PM »
Update - the manual adjustment bolt came last night.  It was a bit fiddly, but today I was able to get it installed and found a way to get some tools on it without burning myself.  It seems to have worked quite well - I slowly tightened down on the adjustment screw and the rattle slowly quieted down:
https://youtu.be/GEFcueAWPXM
I'm not sure if this is where it really wants to be, but it's so much quieter after tightening just a bit that I'm going to ride it a few miles and see what happens...
« Reply #20 on: September 06, 2020, 09:55:05 AM »
So pleased for you that its running.  :) :)
I plan to be where you are by the end of this month.
I know I bought mine with a declared cam chain rattle - I just don't want any other nasty sounds.
When the frame is being powder coated I will then sort out the cam rattle, take the head off, check piston tops etc.
Offline mattsz
« Reply #21 on: September 06, 2020, 11:35:13 AM »
Thanks Macabethiele!  And, sorry for cluttering up your shiny new project thread with all that petcock talk, we really should have moved it somewhere else!  :-[
My time-frame has been a bit longer than yours... I got the bike almost 2 years ago!  And I haven't done any major work on the engine, it's just been puttering with many, many odds and ends just to get the bike road-worthy to see if the engine works...
