Author Topic: Evaporust Trial on fuel tap front plate.  (Read 4032 times)
Offline kent400
Re: Evaporust Trial on fuel tap front plate.
« Reply #15 on: September 12, 2020, 11:25:04 AM »
You will find a selection of variable power supplies here www.gaterosplating.co.uk you need one that has a fine voltage adjustment, a digital display and goes down to point 5 of a volt.
I bought one on fleabay. Ash is the best one who will know which is best although he probably made his own.
« Reply #16 on: September 12, 2020, 12:08:41 PM »
My Evaporust is working really well the tank inside is looking almost brand new in many places but not everywhere yet.
« Last Edit: September 13, 2020, 10:16:51 AM by Macabethiele »
Offline Greg65
« Reply #17 on: September 13, 2020, 08:06:43 AM »
As I understand the process the ampage is the critical factor that drives the plating process, hence the 100 mAmps per square inch. The power box I borrowed allowed me to set ampage and the box adjusted the voltage, I often had nearly 0.5V showing so a measurement of the amp draw is essential.
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
« Reply #18 on: September 13, 2020, 10:18:19 AM »
I will take that onboard if I decide to try it - my BiL Dave has a kit of some sort but no solution yet.
« Reply #19 on: September 13, 2020, 11:16:38 AM »
I did a lot of my own plating a few years ago with chemicals from Gateros plating who are quite cheap and very helpful. For instance, if you want half the amount they normally sell,  they are flexibe and will do that. I even went to the extent of having a little motor driven spindle with slip rings to feed in the plating power to give more uniform plating. However, commercial plating is so cheap and top quality that I just send everything out now other than small bits I need in a hurry or are mega rare and I fear losing them (like CB92 parts !)
Offline Oggie400F
« Reply #20 on: September 13, 2020, 01:16:39 PM »
Is it possible to rig up some kind of cheap and cheerful digital current controller if using a 12v battery charger as the power source?
It would have to be simple for those of us with minimal elecrickery skills or knowledge. 🙂
The simple filament wire controller included with the kit is very hit and miss.
I'm a Radiographer............I can see right through you!!
1999 VFR800 fix in Pearl Prism Black
1978 CB750F1 in Candy Presto Red
1976 CB550F Supersport Brat Bike in Black
1976 CB400F in Varnish Blue - project bike in many bits.
« Reply #21 on: September 13, 2020, 02:36:30 PM »
You can use an LM338 reguator in constant current limit mode...
https://i.stack.imgur.com/gFUuV.png
« Last Edit: September 13, 2020, 02:40:47 PM by AshimotoK0 »
« Reply #22 on: September 13, 2020, 04:06:07 PM »
Ash.
There aren’t many on here will have any idea what you are on about
2022 Tiger Sport 660
« Reply #23 on: September 13, 2020, 06:49:14 PM »
Ash.
I think you are wrong there Steve ..Ian is an 'ull lad  ;D and keen to learn... he's already made and used a version of the Ashimoto curing oven :)   ;D  Its only a three legged device and a resistor & capacitor after all. Ian you coud probably used the resistance wire you got with your basic kit as a variable resistor (R1 in circuit)  and I can get you an LM338 no probs for free. Needs a decent heatsink though.
« Last Edit: September 13, 2020, 06:51:34 PM by AshimotoK0 »
Offline philward
« Reply #24 on: September 13, 2020, 06:53:13 PM »
All I can say Ash - is 'eh!'
« Reply #25 on: September 13, 2020, 08:20:20 PM »
Offline Oggie400F
« Reply #26 on: September 13, 2020, 11:04:33 PM »
Apologies for Hijacking your thread Ted.
Ash
The circuit appears to be a constant current control circuit irrespective of input voltage.
If I want to make this a variable current controller is it simply a matter of installing a potentiometer in the output side of the circuit as a variable resistor?
Cheers Ian
« Reply #27 on: September 13, 2020, 11:56:04 PM »
Ash
Cheers Ian
Yea just make R1 variable  .. you need constant current for plating preferably.. .sorry for thread  hijack from me too.
« Reply #28 on: September 14, 2020, 05:47:33 AM »
How about a “Do your own zinc plating” thread?
« Reply #29 on: September 14, 2020, 08:40:15 AM »
Pete did a decent post
 http://www.sohc.co.uk/index.php/topic,4908.msg22945.html#msg22945
