Author Topic: bearing spacer "rattle"  (Read 655 times)
Offline billdn
« on: September 17, 2020, 05:14:22 PM »
I'm in the throes of building both wheels having I believe completed the front which runs true and balanced I've noticed the bearing spacer in the hub is loose and appears to rattle, I've not fitted tyres yet or put back in the forks - is this usual or have I missed something? Or does this tighten up when you fit to the forks? The bearing retainer is fully installed as well.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: bearing spacer "rattle"
« Reply #1 on: September 17, 2020, 11:02:44 PM »
‘Bill’ - this is not right as the two bearings will have a massive compression force across them as you tighten the wheel spindle. Bearing fail will follow shortly. The spacer’s job is to take this compression .... see recent thread on all this here...
Tricks & Tips / Re: Front wheel axle spacer
www.sohc.co.uk/index.php/topic,23287.msg209303.html#msg209303
« Last Edit: September 17, 2020, 11:04:45 PM by Lobo »
Offline billdn
« Reply #2 on: September 18, 2020, 08:21:10 AM »
Cheers Lobo, got it now! So I presume the same logic will apply to the rear wheel because that's doing the same thing! Simplez when you know how,  :)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: September 18, 2020, 12:35:07 PM »
Yep, both wheels same-same.
