Author Topic: Removing front wheel.  (Read 774 times)
Offline Bradders
« on: September 21, 2020, 07:59:28 PM »
Evening all. Seem to have a puncture in my front tyre so need to remove the front wheel. Is it easy to remove the front wheel ? Any thing I should be careful about? The Haynes makes it sound easy. TIA.
Re: Removing front wheel.
« Reply #1 on: September 21, 2020, 08:17:21 PM »
It is just as Haynes describes Bradders and very easy. Just make sure you have the front end propped up somehow and you are good to go.
Offline Bradders
« Reply #2 on: September 21, 2020, 08:45:22 PM »
Thanks Julie. I’ve also been looking at the thread on here about supporting the bike with the wheel off. Thanks again.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #3 on: September 21, 2020, 09:13:14 PM »
Just be aware that upon replacement you tighten the leading bolts of the front axle holders first, and only then tighten up the trailing bolts.
These axle holders btw are marked F ... as are oriented.
(and apologies if Haynes has already highlighted this...)
Offline Bradders
« Reply #4 on: September 21, 2020, 09:53:01 PM »
Thanks Lobo that’s very useful. I think Haynes says about doing the front nuts up first but not about which way the clamps go, so thanks.
Offline CB400JAY
« Reply #5 on: September 28, 2020, 06:37:19 PM »
I use a couple of tie downs from the bars to the cross supports in my garage.
« Reply #6 on: September 28, 2020, 06:49:08 PM »
I wedge a block of wood under the sump, cut to the correct size.
Offline Andrew-S
« Reply #7 on: September 28, 2020, 06:59:19 PM »
You may have already seen my earlier post on this but if not, I used a front paddock stand as it gives the freedom to move the forks about too:
Edit: I see you only just up the road in Crowthorne - I'm only too happy to let you borrow it if you want?
« Last Edit: September 28, 2020, 07:01:51 PM by Andrew-S »
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline Bradders
« Reply #8 on: September 28, 2020, 07:13:34 PM »
Thanks for the offer Andrew. I managed ok by using my step ladder suggested on another thread and support under the sump. Had puncture repaired by GS tyres in Wokingham recommended by Steve D. Wheel back on with the assistance of Mrs Bradders. This Forum is great for the mine of useful information I get.
« Reply #9 on: September 28, 2020, 07:17:45 PM »
I hope you said hello to Gary and had look around his posh new shop
« Last Edit: September 28, 2020, 09:42:59 PM by SteveD CB500K0 »
2022 Tiger Sport 660
Offline Bradders
« Reply #10 on: September 28, 2020, 07:21:51 PM »
They were pretty busy but repaired it for me while I waited, all done and dusted in about 15 minutes. So great service.
