Author Topic: Front brake hose sizes question  (Read 403 times)
Offline paulbaker1954
« on: September 23, 2020, 12:35:48 PM »
Am thinking of making up some stainless front hoses
Does anyone know the various thread fitting sizes/threads. There are 2 hoses one goes from Res to union and has 2 banjos but not sure of bolt/banjo size
the other goes from union to Union to brake pipe connector and has a banjo at one end a a straight fitting to the pipe connector
Bike is a K0 USA model and parts list quotes different part no’s for the US and European models but don’t know if that makes any difference to the fitting sizes though
« Last Edit: September 23, 2020, 12:39:15 PM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Erny
  • CB750K7 CB550K1
Re: Front brake hose sizes question
« Reply #1 on: September 23, 2020, 02:28:02 PM »
Don't know exactly for 500 K0, I can give example from my 550 K1 (1975), USA model. I investigated details as I did conversion to Europen (lower) handlebars. Only difference between US and EU/UK model is upper hose length due to higher US bars. All fitings are 100% the same.
So, I advice to measure length of your hoses, specify fittings and order them ;)
I advice Goodridge manufacturer - they have hose that is braided (modern, top quality) and looks like stock (but thinner in diameter). They call it "vintage black", you can order custom length and fitments like stock one
If I remember correctly I ordered lower 340mm long, upper 300mm - but you should verify that on your bike
Example of hose set as I got from them from Goodridge
Note: I finally had to remove that rubber grommet from hose (as it did not match fender hook) as on the picture and keep stock one
« Last Edit: September 23, 2020, 02:29:54 PM by Erny »
CB750K7 US model (1977)
CB550K1 US model (1975)
