Author Topic: Someone has been here before without the clutch tool.  (Read 526 times)
Online McCabe-Thiele (Ted)
« on: October 04, 2020, 09:48:39 PM »
Obviously this is not as it left the factory slightly chewed clutch basket retaining nut with iffy locking tabs.
I guess a special tool is the best option to undo and more importantly tighten up again.
Is there a trick to stop it turning - is the DS Tool the thing to use?
Clutch nut by Macabe Thiele, on Flickr
« Last Edit: October 04, 2020, 09:51:12 PM by Macabethiele »
Re: Someone has been here before without the clutch tool.
« Reply #1 on: October 04, 2020, 10:01:00 PM »
Copper coin between the gears is usual trick
« Reply #2 on: October 04, 2020, 10:14:50 PM »
I must of done thousands of clutches over the years and my tool box has never had a locking tool in it.
All you need is four washers. Put the springs back in place and put 4 x M6 washer that is wider than the spring on the bolts and put the bolts back in. This locks the clutch up to remove the nut with the correct tool and replace the tagged washer  ;)
« Reply #3 on: October 05, 2020, 10:08:12 AM »
Thanks Trigger clutch came out a treat tbh I don't think it was very tight so that helped.
