Author Topic: CB400/4 wheels on a CB550K3 ?  (Read 2934 times)
Offline fazer1k
« on: September 24, 2009, 03:43:10 PM »
Does anyone know if the 400/4 spoked wheels will fit straight onto a CB550K3 ?
Thanks,
Ian
Re: CB400/4 wheels on a CB550K3 ?
« Reply #1 on: September 24, 2009, 04:09:12 PM »
Wheels yes brakes no
Offline fazer1k
« Reply #2 on: September 24, 2009, 04:14:29 PM »
Thanks Bryan, so the front wheel will require a CB550 specific brake disc ? And the rear hub requires a different drum ?
« Reply #3 on: September 24, 2009, 04:15:57 PM »
Doesn't the 400 have an 18" front wheel?
550 = 19"
EDIT: Yep, just looked in the book. The 400/4 has an 18" front.
« Last Edit: September 24, 2009, 04:17:41 PM by SteveD CB500F »
2022 Tiger Sport 660
Offline fazer1k
« Reply #4 on: September 24, 2009, 04:22:24 PM »
550 = 19"
Thanks Steve, that info will save me a few quid and a wasted trip to collect them.
Offline matthewmosse
« Reply #5 on: September 24, 2009, 05:57:07 PM »
I'd check number of bolts holding the front disk on too.............
Offline fazer1k
« Reply #6 on: September 24, 2009, 06:16:07 PM »
Guess that would be 4 bolts.......had the spoke wheels in mind for a longer term replacement of the comstars  :)
Hmm, wonder if the CB400/4 wheel hubs could be used as a basis for rebuilds (new rims/spokes) to 19" front and 18" rear, maybe still an option....
« Reply #7 on: September 24, 2009, 08:18:14 PM »
There are 6 bolts on a cb550 hub to attach disk, I'd geuss that cb400/4 whhels have more in common with cb250 wheels from the sound of it (disk diameter and offset?). Keep looking and some correct cb550 wheels may well surface. Don't be put off by cracked rear hub liners though, it's a bit of a pain but not inpossible to put in new linings if you have a lathe or someone in huddersfield re-lines them for
