Author Topic: Clutch operating camshaft thingy - worn or normal?  (Read 911 times)
« on: October 10, 2020, 03:14:22 AM »
At first glance I thought this was badly worn but looking at the part picture on DS it looks like its how they are designed!
When I reassemble it is there any point in packing it with grease or will the oil in the clutch somehow provide lubrication?
Clutch casing mechanism by Macabe Thiele, on Flickr
Re: Clutch operating camshaft thingy - worn or normal?
« Reply #1 on: October 10, 2020, 07:53:44 AM »
This is normal. As long as the balls in the cage are perfectly round, no rust or flat spots just a smear of grease on the balls is needed. Also remember to change the o'ring  ;)
« Reply #2 on: October 10, 2020, 10:09:45 AM »
The balls are in pretty poor condition not sure what size they are perhaps DS sells them.
« Reply #3 on: October 10, 2020, 11:38:02 AM »
They have not been available for years. PM Julie as i will have some somewhere.
« Reply #4 on: October 10, 2020, 01:47:24 PM »
I've measured them up they are 10 mm bearings - my brother should have some that size - if not I will contact NJ. Thanks
Not sure about the O ring its a small critter do you know the size by any chance?
« Reply #5 on: October 10, 2020, 02:01:09 PM »
The ball bearings are 10.25mm, so 10mm ones will fall out of the little baskets. I think the 10.25 size is specifically licenced to Honda, as I have searched worldwide for replacements and can't find any. Even in imperial, there is no exact equivalent.
« Reply #6 on: October 10, 2020, 03:39:00 PM »
When I measured mine they were 10.12 mm and are more like a golf ball texture. I need 3 that are much better not sure what to do.
Offline Deano400
« Reply #7 on: October 10, 2020, 03:46:35 PM »
Offline cliff7
« Reply #8 on: October 10, 2020, 07:04:20 PM »
13/32" balls are available (0.07mm too big). Does anybody know if these would do. https://simplybearings.co.uk/shop/product_info.php?products_id=38926&vat_inc=true
« Reply #9 on: October 11, 2020, 11:20:22 AM »
I've sourced one from NJ thanks guys. I think 13/32 is too big for the cage and the bit they sit in. The size is closest to 0.4 inch.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #10 on: October 13, 2020, 05:23:09 PM »
10.25mm = 0.40354”
13/32” = 0.40625”
Would a difference of 0.00271” make such a difference?
If they measure 10.12, that’s 0.39842” so a difference of 0.00783; still not big, but too big?
I’m interested to hear wha they thoughts are, because I’d be tempted to say, “close enough”, certainly in the first case.
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
« Reply #11 on: October 13, 2020, 07:48:11 PM »
I suspect that 0.00271" would stop the balls moving within the cage - or at the very least bind. I'm happy to fit the ones from NJ they will be good for many years.
« Reply #12 on: October 13, 2020, 07:52:06 PM »
10.25mm = 0.40354”
13/32” = 0.40625”
It doesn't work as i have tried it many years ago  ;)
