Author Topic: Speedo / Rev Counter Bench Calibrations  (Read 906 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: October 13, 2020, 12:05:01 PM »
A nerdy thread -
1st up a big thanks to Peter / Kent400 for his tips on damping my β€˜750 K2 instruments - oh joy, for the first time in ownership my gauges read something versus everything.
It’s fair job dismantling the instruments, and for the sake of a few minutes I recalibrated both - very accurately.
I used a battery drill to spin the instruments via their own cables, and an iPhone APP to sense the chuck rpm. (taped a magnet to the chuck - iPhone uses internal sensor to give rpm readout.)
Via a little spread sheet with constants (1) front wheel radius and (2) gearing ratios of wheel rpm to speedo drive input rpm ... and (3) crank rpm to rev counter input rpm it converts the drill chuck rpm to both KPH & engine RPM values.
I had to keep the drill spinning at a constant speed whilst I entered that into the spreadsheet. The KPH & RPM values then dictate where you then drop the instrument needle onto its spindle (drill still spinning). A couple of more random drill speeds to double check readings... and the needle(s) can be pushed fully home.
Finally, the speedo needle didn't return to 0 (ie it read 10 KPH at rest) so I then had to gently bend the zero-stop tab down by the speed cap to re-datum 0 KPH.
All now road tested and confirmed accurate via a Radar speed readout board as you enter our village - perfect.
And better still the bike now idles nicely at 1000RPM.... versus the β€˜1200’ of past few years.
It all sounds more complicated that it was... Mrs Lobo & I did the 2 instruments in abouts 1/2 an hour....
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Speedo / Rev Counter Bench Calibrations
« Reply #1 on: October 13, 2020, 04:04:09 PM »
Hi Lobo
I used the same app on the timing nut, just to check my newly damped rev counter at 2000 rpm. It reads a little high there but is about spot on at 5000 and sits at zero when resting. Very handy!
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: October 14, 2020, 05:57:40 AM »
... yep, the Rev counter was the more difficult to calibrate... I opted for accuracy in the 0-3000 range, above this a 200 RPM error slowly crept in.
The speedo was surprisingly linear through all speeds.
