Author Topic: Revs rising on tickover since fitting new fuel tap -weird  (Read 1683 times)
Offline paulbaker1954
Re: Rebs rising on tickover since fitting new fuel tap -weird
« Reply #15 on: October 25, 2020, 07:57:39 AM »
Thanks for all the replies and physics theories, interesting reading
All sorted now by rebalancing carbs and resetting idle screws
Ticking over lovely again 👍👍👍
I'm curious as to what you did in what order. I understand adjusting the idle air screw but what did the rebalancing consist of - was it adjusting an individual slider height?
Rebalanced carbs using a proper vacuum gauge set and adjusting each slide height. All as per the Honda maintenance manual.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
