Author Topic: On going electrical issue.  (Read 3209 times)
« on: October 24, 2020, 03:06:31 PM »
Here’s my dilemma, I have removed wiring harness removed all covering and inspected tested and repaired one or two connections. With harness now back on bike and all connected again I still have the same issue regarding heating of switched black wire and fuse glowing when ignition is on. If anything it is worse after my intervention. The only thing is I’m quite sure the problem is not with the harness. With the black wire disconnected from voltage regulator all is fine. When I test between live spade connector on regulator and frame I get open circuit. So am I being stupid or is there a problem there because to connect live wire to regulator is like putting a live wire to frame or earth. Wish I had another regulator to try on bike. Help!
1978 Honda CB550K3.
Re: On going electrical issue.
« Reply #1 on: October 24, 2020, 03:17:00 PM »
Possible short on white wire to field coil as black goes to white to excite generator
« Reply #2 on: October 24, 2020, 06:37:39 PM »
Is that between white wire and ground Bryan? Just tested and white wire is open to ground!
« Last Edit: October 24, 2020, 06:50:25 PM by Johnny4428 »
1978 Honda CB550K3.
« Reply #3 on: October 24, 2020, 07:53:35 PM »
White wire should go to ground via the field coil if its open circuit its broken somewhere and could short intermittently
« Reply #4 on: October 24, 2020, 08:02:53 PM »
Thanks Bryan, yes no resistance between white wire and frame of bike, I will follow wire back to coil tomorrow. Thanks for your help I will report back findings.
1978 Honda CB550K3.
« Reply #5 on: October 24, 2020, 09:47:59 PM »
If its the 750 check the connections in the lead to alternator, there is a point where the white an green from field connect via bullet connectors and these get hot and melt the insulating sleeves sometimes, same on 500/550 but there is no oil sealing shaped rubber bit to deal with.
Is this a standard reg or an aftermarket combined unit?
« Reply #6 on: October 24, 2020, 10:04:22 PM »
Yes Bryan it’s a 750 with possibly original regulator. I have had the cover off it and it just looks like new on the inside. That lower bullet connectors look as if they have been subjected to a bit of heat.
1978 Honda CB550K3.
« Reply #7 on: October 24, 2020, 10:31:22 PM »
Those connectors could be your problem, the regs are normaly bulletproof but the everything, specially me, is getting older
« Reply #8 on: October 25, 2020, 12:46:44 PM »
Removed cover and generator the day, so getting 2.5 ohm between end white wire and casing. Nothing obvious, seems to be ok between 8 terminal plug and female connector.
« Last Edit: October 25, 2020, 02:05:56 PM by Johnny4428 »
1978 Honda CB550K3.
« Reply #9 on: October 25, 2020, 02:47:22 PM »
Should be infinite resistance white to casing and low resistance white to green.
Maybe white has been trapped and has partially shorted
« Reply #10 on: October 25, 2020, 02:48:13 PM »
Long distance electrical fault finding is like shoveling sand in a hurricane!!!
« Reply #11 on: October 25, 2020, 06:44:49 PM »
Yes Bryan I was thinking it’s not easy for you, I’m staring at it with a meter and still scratching my head. I have put it back together replacing some of the connectors. The reading from white wire at reg to frame about 1.8 to 2 ohm and between green and white wires at reg about 2 ohm as well. I didn’t see any shorts to frame but I didn’t remove coil from casing. I’m still getting a bit of warming at main fuse but dare I say not as bad as before, not right either. I am in time going to completely strip and restore bike so wonder if I shouldn’t waste any more time looking for something that I will probably find through dismantling and inspection.
1978 Honda CB550K3.
Offline cliff7
« Reply #12 on: October 25, 2020, 08:06:42 PM »
Just found this on recent post. Sounds as though field coil resistance too low drawing too much current.
"ALTERNATOR FIELD COIL: using a multimeter set on Ohms scale, verify the resistance between the WHITE and GREEN. It should be about 7.2 Ohms. Also check the coil isn’t grounded; ie measure between the White and battery -ve. ... it should read infinity."
That is measuring at field coil connections.
« Reply #13 on: October 25, 2020, 09:10:03 PM »
When doing resistance checks on low readings first you need to touch the meter probes together, in theory the reading should be zerp but it never is and you need to note this reading and subtract it from any measured reading you get.
2 ohms is very low for a field coil what do you get across all 3 pairs of yellow wires, block connector pulled out
« Reply #14 on: October 25, 2020, 09:37:23 PM »
Thanks Cliff I will try these tests tomorrow.
1978 Honda CB550K3.
