Author Topic: Fitting rubber bits  (Read 1246 times)
Fitting rubber bits
« on: October 25, 2020, 02:10:16 PM »
I was trying to fit a motor on a Dyson DC14, I usually have to spray the rubber mounting with WD to get it to go in but a customer was whinging about the oily smell.  This time I tried something different.
Alcohol hand cleaning gel.
I used it at home to refit the airbox on my son's Lexmoto.   Best stuff I've ever used to fit rubber bits.
Re: Fitting rubber bits
« Reply #1 on: October 25, 2020, 02:40:39 PM »
I use silicone spray but if you squeeze too hard you cant find it again
« Reply #2 on: October 25, 2020, 02:53:55 PM »
The hand gel evaporates off once the parts are assembled,  which is an advantage over silicon spray.
« Reply #3 on: October 25, 2020, 04:42:54 PM »
I use a good spray of carb cleaner. Best to get it right first-time as you can't budge them afterwards.
« Reply #4 on: October 26, 2020, 07:12:36 AM »
Red Rubber silicone grease, that is what it is for  ;)
« Reply #5 on: October 26, 2020, 07:22:11 AM »
And stays loose forever on handlebar grips, but would work well on a vacuum cleaner.
« Last Edit: October 26, 2020, 07:59:37 AM by royhall »
« Reply #6 on: November 04, 2020, 03:44:35 PM »
That would all have been so so useful a few years ago - - - as I stood at the side of the road in Moss Side, happily holding onto my 500/4 with one hand. Something didn't feel quite right but it was only when i was left holding a Baja grip with one hand  (remember those? - foamy things)... that I learnt that hand grips needed sticking on (and no one offered to help me pick her up!)
 Hairspray was the thing in the eighties, but technology moves on!
