Author Topic: Now, how did that get in there?  (Read 1204 times)
« on: October 25, 2020, 08:02:21 PM »
I’m not convinced that found its way in there when I removed generator and cover.
1978 Honda CB550K3.
Re: Now, how did that get in there?
« Reply #1 on: October 25, 2020, 08:28:00 PM »
Looks like the washer from the gearshaft idler that the starter motor drives.
« Reply #2 on: October 25, 2020, 08:46:15 PM »
Yes your right! Didn’t know when I first opened it up but got it out with magnet then looked up parts list. Is it possible for that to slip behind the starter pinion when removing cover?
1978 Honda CB550K3.
« Reply #3 on: October 25, 2020, 08:59:02 PM »
Its defo as k2-k6 suggests - and may have fallen down as you removed the shaft that holds the idler gear
« Reply #4 on: October 25, 2020, 09:07:02 PM »
Yes it will slip out if not careful.
The shaft is just floating and retained by the cover preventing it moving,  if it's pulled out as you withdraw the cover then the washer can just drop off.
« Reply #5 on: October 25, 2020, 09:44:57 PM »
Does the washer go between idler and cover?
1978 Honda CB550K3.
« Reply #6 on: October 25, 2020, 10:38:29 PM »
Yes, it is to  stop the cog rubbing the alternator housing  ;)
« Reply #7 on: October 26, 2020, 06:16:34 AM »
Thanks Trigger.
1978 Honda CB550K3.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #8 on: December 06, 2020, 09:25:40 PM »
I asked exactly the same question once ... :)
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
« Reply #9 on: December 07, 2020, 09:00:08 PM »
Holy shit Sean! Surely not with the float bowls on.
1978 Honda CB550K3.
Offline SeanFD
« Reply #10 on: December 08, 2020, 10:55:27 AM »
Yep. And at leat 500km done.
« Reply #11 on: December 08, 2020, 08:41:54 PM »
Looks like it has been curled round the float valve pin.
1978 Honda CB550K3.
