Author Topic: minimum wiring to run a bike (Yam 600)  (Read 2190 times)
Offline pae
    • Phil's CB650 pages
« on: October 19, 2009, 03:53:02 PM »
Chaps, this is a Yamaha question, but I reckon it probably applies equally (and as the Yam forum are hopeless at communicating I'll ask here).
I've got a 1985 XJ600 project in the garage. This thing runs, but the PO has partly stripped it including pulling most of the wiring off (neatly, may I add).
I want to fire it up before heading into a full stripdown and wonder what's the minimum I'll need to hook up to get it to run? Not worried about charging or anything, just want to connect a battery and fire it up to hear it run.
cheers, Phil
Offline matthewmosse
Re: minimum wiring to run a bike (Yam 600)
« Reply #1 on: October 19, 2009, 07:47:02 PM »
I test run 550 lumps with pair of wires from points to coils, another joining the coils to +tive on battery. earth cable and toutch the starter cable streght to battery, just mind your feet if testing 'on the bench' ;D
Offline JonnyB
    • BatchScan
« Reply #2 on: October 21, 2009, 12:34:03 PM »
If you check the wiring diagram you may be able to workout what's needed or not. There will a bit more for electronic ignition bikes.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
