Author Topic: CJ250T brake pipe  (Read 988 times)
Offline AndyD
CJ250T brake pipe
« on: October 30, 2020, 05:32:12 PM »
Hi,
Struggling to find anyone who can do replacement brake hoses and pipe for the old CJ250T.
Anyone have any ideas?
Cheers,
Andy
Re: CJ250T brake pipe
« Reply #1 on: October 30, 2020, 05:43:53 PM »
Speak to Dan at Legend Motorcycles, he may be able to help.
« Reply #2 on: October 30, 2020, 06:03:23 PM »
Given the lengths and type of fittings i could make you some braided ones, do you want to keep the end metal pipe?
Offline AndyD
« Reply #3 on: October 31, 2020, 08:49:22 AM »
Thanks.
Julie - I tried Legend first as I got the 400 hoses from them recently and they look really good but sadly they don't do any for the CJ.
Bryan - I'm trying to get as original a look as possible so prefer to have the metal pipe if feasible.
I had some made up by Predator a few weeks ago but when I got them the hoses are wrong and I think the pipe is also not correct. They are not sure when they can make new ones so I was hoping to find an alternative.
Cheers,
Andy
« Reply #4 on: October 31, 2020, 10:33:02 AM »
Have you spoke to Dan at Legend ? Give him the measurements of your old lines. I think they are the same as a 400 four  ;)
Offline rosco
« Reply #5 on: October 31, 2020, 11:02:25 AM »
@Hi Andy   Silvers sell an aftermarket lower hose @ £21.54
              CMSNL sell aftermarket hoses Upper @ 25 euro
                                                         lower @ 25 euro
               But as Trigger says they do look the 400f set up Try measuring your 400 ones and compere with CJ250T
Offline AndyD
« Reply #6 on: October 31, 2020, 12:01:06 PM »
Thanks again
I did originally hope that the brakes would be the same as the 400 but sadly not the case.
The two hoses are both a small mount shorter than the 400 ones - by about 25 - 30mm which probably would fit but pushes the hoses 'out' of line quite a bit.
For the pipe it's hard to tell, definitely a different part number but I can't compare so easily as the CJ pipes are all damaged / cut on the old bikes.
Having a good look it might be possible to fit the 400 pipe but I need to get the front end together first to check for sure.
I think the difference may be due to the CJ having a slightly longer fork slider for some reason which shortens the hoses and changes the run of the pipe and clamp position etc.
I thought the forks were common parts until I dismantled the two bikes and found that one had shorter sliders and when I compared them to the 400 they matched up.
I'll give Legend a call and see if they can do 'special' hoses or only supply standard kits etc.
Cheers,
Andy
