Author Topic: Double disk for CB750 four K0  (Read 535 times)
Offline Sgt.Pinback
« on: November 05, 2020, 07:20:28 PM »
Probably been asked several times....
I want to give my 750 K0 (with wider k0 hub!) a second front disk.
What do I need on the axle (apart from longer bolts): another speedodirve and/or anotherNr. 8 and/ or another No 9 ?
If so, need the parts.
Thanks in advance
cheers, Uli
Re: Double disk for CB750 four K0
« Reply #1 on: November 05, 2020, 08:40:36 PM »
You dont use any No9 and you only need 1 speedo drive gearbox BUT the drive needs to look like the one in the pic you posted NOT the later one with horizontal ears, you may still have to take sp
Mall bits out of the disc carrier to get the drive plate in
Offline sprinta
« Reply #2 on: November 06, 2020, 12:26:11 PM »
Hi
If you follow this post you can see what I did and used which may be of help, though this was for a K2 with the narrower front hub.
http://www.sohc.co.uk/index.php/topic,21171.0.html
« Last Edit: November 06, 2020, 12:28:25 PM by sprinta »
