Author Topic: engine  (Read 1385 times)
Re: engine
« Reply #15 on: November 15, 2020, 09:47:50 AM »
Certainly if you can get a competent enlarged thread cut with a spigot to adapt,  then it would give you a good engineering solution to it.
The threads are only that bore size to flow oil through the bolt centre and not required to take much load in a conventional sense. Obviously to sucure the oil filter is a prerequisite but it would ordinarily be easier than the weld and remachine route.
Offline steven400/4
Re: engine
« Reply #16 on: November 15, 2020, 10:34:38 AM »
yes i agree mate i,ll wait to see what terry comes back with  :) :) :)
cb400f2 x7
honda ss 50
gsx 1400
Offline robvangulik
  • Honda Fourever
Re: engine
« Reply #17 on: November 15, 2020, 07:55:23 PM »
thanks k2 k6 i ordered a tap yesturday before  i saw your reply lol i have sent that terry a message asking what he thinks what i can do
Terry from Oz?
At least you won't have to explain anything, he'll understand what you're on about! :)
Offline steven400/4
Re: engine
« Reply #18 on: November 16, 2020, 03:08:47 PM »
i,ve sent terry a message but no reply as yet
cb400f2 x7
honda ss 50
gsx 1400
Offline robvangulik
  • Honda Fourever
Re: engine
« Reply #19 on: November 16, 2020, 07:51:23 PM »
He's probably making the neighborhood unsafe, it's spring over there ;)
Offline steven400/4
Re: engine
« Reply #20 on: November 18, 2020, 08:00:16 PM »
all sorted tapped the filter in engine put new bolt in all seems ok no leaks when it was running so i,ll change oil and filter at week end and check again  ;D ;D ;D ;D ;D
cb400f2 x7
honda ss 50
gsx 1400
