Author Topic: Fusebox looks a bit cramped/  (Read 636 times)
Offline waffey
« on: November 15, 2020, 02:28:27 PM »
Hi,
just installed a new fuse box but its touching the starter relay, looks a bit tight. Is the relay in the right orientation, looks like it in my manual but it doesn't feel right????
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Re: Fusebox looks a bit cramped/
« Reply #1 on: November 15, 2020, 02:34:40 PM »
Not normaly that close
« Reply #2 on: November 15, 2020, 02:34:51 PM »
It is all a bit tight in that area but not that tight
Offline TrickyMicky
« Reply #3 on: November 15, 2020, 04:15:42 PM »
From your photo, it doesn't look like an original, certainly looks bigger. Can you post the W x L dimensions?
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: November 15, 2020, 04:26:36 PM »
I changed my own fuse box recently because it was in danger of burning out, it also turned out to have mismatched fuses in it. What I see in the pic does not look like the original or DSS replacement in my own bike. I think you need a different unit in there myself.
1978 CB400F2 called Elen.
Offline waffey
« Reply #5 on: November 16, 2020, 08:28:47 AM »
I measured it 70mm tall by 40mm wide. It is a DSS after market one. I checked with the old one i took off and its the same size.
Nurse Julie, it looks like your starter relay is set the opposite way to mine? Maybe this is my error, will take another look tonight
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #6 on: November 16, 2020, 10:24:05 AM »
This photo is not of my bike but shows that they are close but not touching - the memory in the cables to the solenoid might just push it to the right too much?
.more wiring routing by Teddy Bagshaw, on Flickr
« Last Edit: November 16, 2020, 10:26:06 AM by Macabethiele »
