Author Topic: CB550 K0 #449  (Read 2421 times)
Offline Kelly E
  • Geriatric Hooligan
CB550 K0 #449
« on: November 26, 2020, 03:53:59 AM »
I thought I would put up some picures of the 74' 550 build that I just finished. I've had it for 3 years but worked on other bikes for a year in the middle of the project. Here's some motor shots.
The Rust Brothers Garage Collection
1974 Honda CB550 K0
1975 Honda CB400F Super Sport
1979 Honda CB750F Super Sport
1980 Suzuki GS1100E
1982 Honda CB900F Super Sport
1983 Honda CB1100F
1984 Honda VF700S Sabre
1984 Honda VF1000F Interceptor
1990 Moto Guzzi 1000 Le Mans
1994 Kawasaki Concours ZG1000
2006 Harley Davidson Fat Boy
Offline Kelly E
Re: CB550 K0 #449
« Reply #1 on: November 26, 2020, 03:56:33 AM »
The motor going into the frame.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #2 on: November 26, 2020, 04:07:15 AM »
The rear sets I made from the stock peg mounts and a set of 82' V45 Sabre foot peg mounts. I cut 150mm out of the middle of the back fender after I removed the mount. Then welded back to the mount with the taillight wiring tunnel intact. For the seat I modified the stock base so it still uses the hinge and seat lock. A shop did the foam and the seat cover. We went with Hagon shocks and installed needle bearings in the swingarm.
« Last Edit: November 26, 2020, 04:37:10 AM by Kelly E »
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #3 on: November 26, 2020, 04:15:34 AM »
Then we finished up the rear lights and moved on to the front end. We assembled it and got the fork brace and front fender attached. We used Progressive brand springs and tapered roller bearing in the steering head. The front fender got 230mm cut out of the middle with the seam under the fork brace.
« Last Edit: November 26, 2020, 04:35:40 AM by Kelly E »
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #4 on: November 26, 2020, 04:20:36 AM »
Then it was time for the headlight bucket and getting everything plugged into the new wiring harness. Time for the gauges.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #5 on: November 26, 2020, 04:28:54 AM »
Now the front end is finished up with the controls mounted.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #6 on: November 26, 2020, 04:32:22 AM »
Just waiting on the mirrors and need to sort out the jetting.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Re: CB550 K0 #449
« Reply #7 on: November 26, 2020, 10:17:47 AM »
Good work.
Very nicely done.
How does she ride?
Offline Kelly E
Re: CB550 K0 #449
« Reply #8 on: November 26, 2020, 03:41:41 PM »
Good work.
Very nicely done.
How does she ride?
I haven't really ridden it yet, just around the shop. Still waiting on some new jets.
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Re: CB550 K0 #449
« Reply #9 on: November 26, 2020, 11:24:41 PM »
Very dark green on the K0. Light green on the K2/F1  ;)
Offline Kelly E
Re: CB550 K0 #449
« Reply #10 on: November 27, 2020, 12:51:27 AM »
Not being critical or anything but the clocks look wrong, I thought they were supposed to be green faced
They are the original gauges, it is a very early 550. It was built in 8/73', it is why I didn't cut anything on the frame. I took all of the front end apart. I don't think the gauges had ever been off before. The gauges are Nippon Denso.
« Last Edit: November 27, 2020, 01:08:04 AM by Kelly E »
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #11 on: November 27, 2020, 03:36:15 PM »
Cool, thanks. Whatever the case I like the blue gauges and they both work. 8)
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline Kelly E
Re: CB550 K0 #449
« Reply #12 on: November 28, 2020, 01:48:49 AM »
Today I remembered I have a decent looking set of green faced gauges that I forgot I bought two years ago. They only have 10k miles on them. I got them from a guy chopping up his bike into a bobber. Still like the faded blue gauges better. ;D
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
Offline heli_madken
Re: CB550 K0 #449
« Reply #13 on: November 28, 2020, 11:40:01 AM »
I think the gauges and the bike look great as they are well done. You haven't really gone for originality so why do you have to change them to green? if you like them as is leave them, I would
Offline Kelly E
Re: CB550 K0 #449
« Reply #14 on: November 28, 2020, 03:42:03 PM »
I'm not changing to green, everybody has green gauges:D. I was just saying that I had found a green set that I bought two years ago in case the blue gauges fail. Thanks for the compliment on my build. ;D
1974 Honda CB550 K0
1980 Suzuki GS1100E
1983 Honda CB1100F
