Author Topic: spares hoard  (Read 2588 times)
Offline mickwinf
spares hoard
« on: December 05, 2020, 04:33:26 PM »
Just picked up a load of spares for 500/550 as a job lot, including an engine plus extra head etc and lots of other chassis and brake parts. I will be selling some of these to re-coup the cost so if anyone needs anything specific just ask.
Offline mickwinf
Re: spares hoard
« Reply #1 on: December 05, 2020, 10:11:48 PM »
hi oddjob its a 550 engine.
« Last Edit: December 06, 2020, 01:22:32 PM by mickwinf »
Offline mickwinf
Re: spares hoard
« Reply #2 on: December 06, 2020, 01:29:19 PM »
found some treasures in the pile, an undamaged fuse box cover which will go on my F2, and also a pair of headlamp brackets for F2 and K3 which seem in good condition except for a slight rust patch which may be a hole. Also a rear brake drum for the earlier 500/550 with the flat brake plate and the liner seems to be not cracked. Just having a look at the complete engine, it does seem to be seized up so investigating.
Re: spares hoard
« Reply #3 on: December 06, 2020, 01:50:28 PM »
Long shot but have you got rubber spare fuse holder that goes in tool tray on 500 Mick?
Sent from my moto g(7) power using Tapatalk
Re: spares hoard
« Reply #4 on: December 06, 2020, 03:45:43 PM »
Thanks Ken, I'll message Julie!
Offline mickwinf
Re: spares hoard
« Reply #5 on: December 06, 2020, 05:40:27 PM »
Phil, no sorry i have not seen one, Julie will sort you out. Oddjob i think i am keeping the engine for now at least, however i did get some other engine parts, a pair of crankcases with head and barrels and cam cover, not sure if its the pinned one or not i will check tomorrow. was it just the cam cover you need? oh just checked on pic and it is the pinned one
« Last Edit: December 06, 2020, 05:55:10 PM by mickwinf »
Re: spares hoard
« Reply #6 on: December 06, 2020, 05:48:44 PM »
Just had reply from Julie and Trig hasn't had any made for a few years
Offline mickwinf
Re: spares hoard
« Reply #7 on: December 06, 2020, 05:57:37 PM »
more stuff
Offline Oggie400F
Re: spares hoard
« Reply #8 on: December 06, 2020, 09:02:59 PM »
Hi Mick
Is there a rear mudguard and lamp from a 550 in there?
Offline mickwinf
Re: spares hoard
« Reply #9 on: December 06, 2020, 11:53:44 PM »
yes there is but has some damage at the end, mudguard is a k3 one i think with three holes. I have two lamp brackets, one k3 type which has a bit missing where the number plate mounts, the other is a chrome US type and in good condition
Offline mickwinf
Re: spares hoard
« Reply #10 on: December 07, 2020, 02:08:31 PM »
Hi oddjob, sorry to hear of your health issues, i will have a close look at the journals and the fork ears, although another member has first dibs.
Offline mickwinf
Re: spares hoard
« Reply #11 on: December 08, 2020, 08:40:51 PM »
Bad news ken, the journals are fine but on close inspection there is a chunk broken off at the edge, not sure if it could be welded. I have put a pic of the damage.
Offline mickwinf
Re: spares hoard
« Reply #12 on: December 08, 2020, 10:43:28 PM »
i have another one that is also cracked and in worse condition so can strip if you just need the internals, £25 inc post.
Offline peterengland
Re: spares hoard
« Reply #13 on: December 09, 2020, 03:42:49 PM »
Mine is the same but a bit worse, but hey, no leaks and is just fine and dandy!
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
Offline mickwinf
Re: spares hoard
« Reply #14 on: December 09, 2020, 07:15:16 PM »
Hi Ken yes its the same but the journals are more worn, i will pm you
