Author Topic: 500k2 Carb Actuating Bar Removal  (Read 618 times)
« on: December 13, 2020, 05:51:48 PM »
How do I remove the actuating bar? (want to re-zinc the part on it) I've taken the half moon weddges out the bar but when I lightly tap the end of the bar, it feels like its hitting a pin or something but can't see any.
Re: 500k2 Carb Actuating Bar Removal
« Reply #1 on: December 13, 2020, 06:06:51 PM »
There is a pin that needs drilling out Phil.
« Reply #2 on: December 13, 2020, 06:10:14 PM »
« Reply #3 on: December 13, 2020, 06:15:57 PM »
Thanks Julie - any idea on the size?
« Reply #4 on: December 13, 2020, 06:18:32 PM »
You should be able to see the pin Phil, it's that size drill bit 🤣🤣🤣🤣
« Reply #5 on: December 13, 2020, 06:21:34 PM »
Thanks again Julie
« Reply #6 on: December 13, 2020, 06:51:40 PM »
Do not try to force the bar until you remove the pin, this will damage the bronze bush.
I drill the pin out and then tap a thread and make a small screw with a nipple on the end to sit in the groove of the bar, as per pictures.
« Reply #7 on: December 13, 2020, 09:27:17 PM »
Pin out - and that was my exact plan Graham - thanks for the pictures
