Author Topic: 500K2 Electrical Connection Blocks  (Read 1509 times)
« on: December 21, 2020, 03:19:54 PM »
Just dummy fitting new harness and having a mental block on the electrical connection blocks on the mounting bracket under the LH side panel.
Top connection is from the loom, middle from alternator/nuetral/oil presure sub loom - but what goes into the bottom connection block?
Re: 500K2 Electrical Connection Blocks
« Reply #1 on: December 21, 2020, 03:43:46 PM »
Sorted and mental block dislodged! Obviously rectifier but god knows where it is - remember testing it and repainting
« Reply #2 on: December 21, 2020, 05:31:38 PM »
I can't seem to locate the rectifier off the 500 (I refurbed and bagged up all the electrical components about 4 months ago - I am sure I remember repainting and cleaning the wires on the rectifier but can't find it now). I've got a spare from the 750 that I am sure I had to change because of a charging issue on the k6 cafe racer I built.
So I've tried to test it using the diode setting on my multimeter.
I'm testing across the green to each yellow lead with black multimeter lead on green and red lead on each yellow wire on rectifier connection block - I'm getting a reading of '592' on each yellow and if I reverse the multimeter leads, I get the same reading. This doesn't seem right getting the same readings!
Am I testing it correctly?
« Reply #3 on: December 21, 2020, 05:35:04 PM »
I thought the middle block on the K0 was round pins?
Also check the fuse wire, it looks to me to be showing signs of melting in the past.
Not sure what you mean about round pin on K0 Kens? Mine's a K2. Will check the fuse wire
« Reply #4 on: December 21, 2020, 05:37:46 PM »
Ken only the early K0 had the round pin blocks.
« Reply #5 on: December 21, 2020, 09:30:58 PM »
I thought it was all of them Bryan, odd that Honda would change it mid run so to speak
Oh my mistake, I thought Paul’s was a K0 for some reason.
Have you started on the Christmas Port early Ken? Wrong model, wrong person (Paul>)!
Any guidance on testing the rectifier?
« Reply #6 on: December 21, 2020, 10:26:01 PM »
Found a post from Mike explaining test process
« Reply #7 on: December 21, 2020, 11:01:45 PM »
Followed Mikes advice as follows (with rectifier completely disconnected)
'Establish which is positive of the rectifier and which is negative.
Using a multimeter on the diode range (or ohms range if there's no diode range)
Put the red meter lead on the negative and test each yellow lead of the rectifier in turn.  Then do the same tests with the black meter lead on the negative.
You should have a reading on all 3 in one direction but no reading the other direction.
Now put the black lead on the positive,  check all 3 yellows .
Do same with the red lead on the positive.
As before,  a reading in one direction but nowt the other direction.'
However, I get a reading (diode range) when putting red meter lead on neg on rectifier AND with black lead on rectifier negative
I get nothing when putting black meter lead on postive or the negative rectifier lead?
« Reply #8 on: December 22, 2020, 08:15:09 AM »
Hey changed cos the spades make better contact and dont melt as easy
« Reply #9 on: December 22, 2020, 08:35:06 AM »
Quote
That's as it should be.  You're measuring through all six diodes in one go.
Offline Moorey
« Reply #10 on: December 22, 2020, 09:45:40 AM »
Quote
 On the countdown now Mike.
« Reply #11 on: December 22, 2020, 10:18:43 AM »
Wot?
« Reply #12 on: December 22, 2020, 10:23:16 AM »
Thanks Mike - this one came off the K6 project when it wasn't charging - changing for a spare cured the problem but if this one is checking out ok, it was maybe just a dirty connection that was cured when the alternative rectifierwas plugged in.
Anyway, its a result that this ones working (still don't know were I have put the original 500k2 rectifier though - too many spares for too many bikes!)
Thanks again
« Reply #13 on: December 22, 2020, 10:35:13 AM »
Don't rely on testing all six diodes at once (positive to negative).
The worst case scenario is four of the diodes are duff and you're only reading through a pair of diodes connected to one phase.  In that case, you'll get charging but not a lot.
Certainly not enough to have any lights on.
« Reply #14 on: December 22, 2020, 12:00:25 PM »
Haven't tested pos to neg Mike - tested as per your recommended way but
'I get a reading (diode range) when putting red meter lead on neg on rectifier AND with black lead on rectifier negative
I get nothing when putting black meter lead on postive or the negative rectifier lead?'
Am I missing something in my ignorance?
