Author Topic: Seat cover fitting  (Read 657 times)
Offline Athame57
    • SeaWitch Artist
Seat cover fitting
« on: January 09, 2021, 04:31:21 AM »
Has anyone fitted a seat cover before, is easy as it looks or should I get a proffie? I want to get some of those  tiny studs & washers you get for clipper it under the seat , what might they be properly called , from where to get if not supplied with a DSS seat cover (CB400F)
1978 CB400F2 called Elen.
Offline SumpMagnet
Re: Seat cover fitting
« Reply #1 on: January 09, 2021, 12:37:20 PM »
I have indeed fitted a seat cover in the past.
Would I do it again....not a chance!
Replacement seat cover kits used to be common, and fitting them was fairly easy. Fitting them so they were tight, even and looked good was absolutely not. I was fitting a cover so I could use the seat...the old cover having been ripped...gaffa taped...ripped more...taped more...and so on until it was an eyesore. so pretty much any result was going to be better.
Only time I got a result I was proud of was on a plastic seat base using a staple gun. Minimum 4 arms required.....
I have the utmost respect for professional trimmers, whose skills I lack!
CB750F2 - in pieces
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: January 09, 2021, 08:58:37 PM »
That's it then...someone else can do it for me!  ::)
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #3 on: January 10, 2021, 09:51:53 AM »
I got mine from Morretti and fitted it using clamps, impact adhesive and the 500/4 has gripper things built in which help a bit.
IMHO the best source if he still does it is Morretti as he supplied the correct pattern, and he may do it for you.
Morretti Seat covers
  morrettidirect@aol.com<mailto:morrettidirect@aol.com>
  01453766137
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
