Author Topic: Cb750 front brake disc  (Read 726 times)
Offline SteveCR7
« on: January 15, 2021, 07:42:47 PM »
Hi, can anybody identify the brake disc below from the markings. It’s fitted to my Rickman and I need a replacement. Also, what model discs are interchangeable with the same offset from mounting face to disc surface. Thanks steve
76 Rickman CR750 (resto in progress)
73 Kawasaki H1D (sunny day madness)
02 Triumph Sprint ST955 (commuter and long distance)
Re: Cb750 front brake disc
« Reply #1 on: January 16, 2021, 06:11:59 AM »
Size is a better identifier
Offline SteveCR7
« Reply #2 on: January 16, 2021, 11:33:35 AM »
The disc is 296 diameter and the offset from the mounting face to the inner disc face is about 14mm. I can’t be definite as the disc is warped, which is why I need a replacement.
Offline Skoti
« Reply #3 on: January 16, 2021, 12:33:08 PM »
This one's 296mm, but I'm not sure what the offset is.
https://bikes.ebcbrakeshop.co.uk/ebc-bike-brakes-prolite-left-steel-disc-md1062ls_p1158486.htm
Anyhow I've got one fitted to my CB750F1 and it stops in the rain unlike the OE Honda one...
Edit.
I've just measured the offset on the old OE Honda disc I removed and it's also 14mm, so the EBC MD1062LS should fit OK.
« Last Edit: January 16, 2021, 12:43:47 PM by Skoti »
1976 Honda CB750F1
« Reply #4 on: January 16, 2021, 01:51:42 PM »
That's useful info, thanks
Offline SteveCR7
« Reply #5 on: January 16, 2021, 03:18:46 PM »
F Models have a 5 bolt hub the earlier models were 6. Hopefully the offset is the same across all front discs
Offline Skoti
« Reply #6 on: January 16, 2021, 04:06:36 PM »
Steve,
well noticed, the fitting list on that EBC link I provided earlier must be incorrect.
"F Models have a 5 bolt hub the earlier models were 6. Hopefully the offset is the same across all front discs"
Sorry and I hope I've not misled anyone...
1976 Honda CB750F1
