Author Topic: Finally retired and building my project bike  (Read 5477 times)
Re: Finally retired and building my project bike
« Reply #45 on: July 12, 2023, 06:06:09 PM »
My 400 & 500 have the nylon type ring on the one static pad back.
I think Grahame is talking about the piston to pad contact being convex or concave.
Are you sure that is the correct fitment?
I understand it fits between piston and moving pad
« Reply #46 on: July 12, 2023, 06:57:33 PM »
TBH I can't remember now where that plastic washer went it's over a year ago now - my manual does not even show it as a part. I have it in my head that if it was on the static side otherwise it would sit inside the piston & serve no purpose.
There might have been a leaflet in the pad box someone here will have the right answer?
« Reply #47 on: July 12, 2023, 07:18:59 PM »
Goes on the back of the moving pad.
« Reply #48 on: July 12, 2023, 07:22:21 PM »
That makes sense in terms of anti-squeal function.
Updated:- A nagging doubt made me check my 500 front calliper - the nylon type washer can only  fit on the piston side as its a different shaped pad back to the fixed side.
« Last Edit: July 12, 2023, 07:54:21 PM by McCabe-Thiele (Ted) »
Offline gamma
« Reply #49 on: July 13, 2023, 06:17:50 PM »
Battery is in and not leaking as of yet.
Now working on fitting front indicators to the fairing, making brackets to fibreglass inside fairing
Offline gamma
« Reply #50 on: July 16, 2023, 07:39:51 PM »
Indicators done.
Getting closer to starting the engine.  I’ve put a very small squirt of diesel and 2 stroke oil in the bores and turned the motor on the starter. Oil light went out after about three bursts.
