Author Topic: Rubber manifold K3 & 069A  (Read 480 times)
Offline thomaspigeon
« on: February 02, 2021, 09:33:18 PM »
Hi everyone,
I tried to look for this answer everywhere but it seems I can find a straight answer, I have a 550 k3 with 069A carbs. The rubbers for the manifold are the K3’s one which means the carbs don’t seat against the rubber (I have a gap of a few mm).
Now that could create  some vacuum issues. The carbs has 2 grooves and my rubbers only 1.
If I buy a manifold rubber for a F1 would that work?
I’ve seen that the intake manifold got 2 grooves while mine has only one so I’m not sure if that would work.
Re: Rubber manifold K3 & 069A
« Reply #1 on: February 02, 2021, 11:58:59 PM »
Fit 500 or early 550K/550F manifolds and rubbers, that should all fit properly, manifold O rings to head are same as tappet cap ones
« Reply #2 on: February 03, 2021, 09:08:19 AM »
To fit 069A carbs to a K3, you will need the 500/550F type manifolds and the rubbers  ;)
« Reply #3 on: February 04, 2021, 12:36:22 AM »
Brilliant! Thanks everyone!
