Author Topic: Pressure and Volt Gauge  (Read 1007 times)
Offline Steris
« on: February 04, 2021, 01:28:59 PM »
Morning All..
I wanted a pressure gauge and a volt meter for my CB500K2. I couldn't find one available commercially so set about making one.
Quite pleased with the result, amazing what you can do when you're locked down and bored  :) :)
Andrew
Re: Pressure and Volt Gauge
« Reply #1 on: February 04, 2021, 02:04:43 PM »
That looks pretty neat nice combination of analogue & digital displays.
« Reply #2 on: February 04, 2021, 05:11:40 PM »
What is a normal oil pressure?
2022 Tiger Sport 660
« Reply #3 on: February 04, 2021, 05:31:20 PM »
The relief breaches at 60psi I believe,  and they'd probably run 45psi and upwards when hot.
The oil light extinguishes much lower,  so really indicates if it's pumping and sufficient to not suspect a mechanical problem exists.
Offline Steris
« Reply #4 on: February 05, 2021, 08:55:43 AM »
Hi OddJob
The display is 23mmx10mm. Off ebay £2.80
Hope that helps
Andrew
