Author Topic: Alternator phase wire broken  (Read 415 times)
Offline Charlie J
« on: February 18, 2021, 04:24:49 PM »
Having rebuilt the engine/gearbox and refitted it to the freshly painted frame, I’m now starting on the electrical system which is generally in poor condition or missing altogether. As can be seen in the photo, one of the 3 yellow phase wires is broken. Can anyone tell me please if I can just unwind the binding where the white paper pointer is, then locate the end of the broken wire and solder the two pieces together and then redo the binding holding the phase wires in place?
Thanks in advance
Charlie
Online Bryanj
Re: Alternator phase wire broken
« Reply #1 on: February 18, 2021, 04:42:23 PM »
Basic answer yes but you shouldnt need to unwind the binding if you removed the assembly from the cover, if the actual varnished wire is broken(unusual) you need to scrape varnish off to get solder to stick and get some fluxed,leaded solder if you can
Offline Charlie J
« Reply #2 on: February 18, 2021, 05:00:38 PM »
Thanks Oddjob/Bryan. I’ll give it a try tomorrow.
