Author Topic: Cb 550 ss spain  (Read 13284 times)
Re: Cb 550 ss spain
« Reply #15 on: March 16, 2021, 07:02:39 PM »
You can use this geuine primary chain (same chain/manufacturer) at under half the Honda price
- and as in Europe, no duties
https://www.motorcyclespareparts.eu/en/kawasaki-parts/920571011?currency=GBP&withvat=1&gclid=EAIaIQobChMIxZvMhMah7gIVyrTtCh39NQiJEAQYASABEgIWtPD_BwE
Offline murdock
Re: Cb 550 ss spain
« Reply #16 on: March 16, 2021, 09:19:23 PM »
Thank you very much for the information, it is very useful, there are also guzzi parts, it is very useful to me, I will buy the kawasaki chain
Offline murdock
Re: Cb 550 ss spain
« Reply #17 on: March 16, 2021, 09:23:25 PM »
2015
Offline murdock
Re: Cb 550 ss spain
« Reply #18 on: March 16, 2021, 09:25:26 PM »
mas
Offline murdock
Re: Cb 550 ss spain
« Reply #19 on: March 17, 2021, 02:16:15 PM »
I'll see if I find them, my girl tends to throw away the things that for her are filthy, I suppose this is a common problem that a large part of the population suffers
Offline murdock
Re: Cb 550 ss spain
« Reply #20 on: March 18, 2021, 08:19:31 PM »
Hello, as I had a leak in the cap of the pan, I decided to remove it to repair it and look at the chain.
from below I move it easily with a finger upwards, it also has play to the sides, I found some marks that confirm its flight
Offline murdock
Re: Cb 550 ss spain
« Reply #21 on: March 18, 2021, 08:23:39 PM »
It is also somewhat dirty inside, I have already bought a chain, I must find out what else to ask for since I am going to open it, I should do the right thing
Re: Cb 550 ss spain
« Reply #22 on: March 18, 2021, 08:56:38 PM »
The 550 has more clearance to the main oil gallery than the 500 so chain has to be really worn to cause bad damage, its the sort of thing uou change if you have to split the cases for another reason
Offline murdock
Re: Cb 550 ss spain
« Reply #23 on: March 18, 2021, 09:38:19 PM »
enlarging the photo you can see the chain pins as if they were touching somewhere the plates are black but they are not
I should buy the primary shaft rubbers, the bearings, I still don't know whether to order the transmission ones as well, I don't think they are necessary
Re: Cb 550 ss spain
« Reply #24 on: March 18, 2021, 10:02:51 PM »
Is the grey marking on the chain just old oil, can it be wiped off with a tissue?
Offline murdock
Re: Cb 550 ss spain
« Reply #25 on: March 18, 2021, 10:42:56 PM »
Chain pins are that colour because they were that colour originally, same for the plates, they started off that colour.
If your changing the chain, change the damper rubbers as well.
Yes, they are without any doubt, but should I also change the primary gear bearings?
18 . 19 .and 26 ?
Offline murdock
Re: Cb 550 ss spain
« Reply #26 on: March 18, 2021, 10:45:32 PM »
I think the number 19 is the most suffered, but it seems that it is no longer available as an original replacement
Offline murdock
Re: Cb 550 ss spain
« Reply #27 on: March 19, 2021, 07:34:28 PM »
yes ,it's just a shine from the oil
Offline murdock
Re: Cb 550 ss spain
« Reply #28 on: March 19, 2021, 07:39:39 PM »
Since I am going to open the engine, someone could tell me what other parts I should buy, at the time I will look at the crankshaft bearings and connecting rods, the pistons and rings are easy to get, no problem
Re: Cb 550 ss spain
« Reply #29 on: March 19, 2021, 08:23:01 PM »
Gasket kit
Seal Kit
Primary and cam chains
Primary damper rubbers
It is unusual to find shells worn but they can be damaged by dirty oil
