Author Topic: Cb 550 ss spain  (Read 13299 times)
Re: Cb 550 ss spain
« Reply #75 on: April 05, 2021, 12:00:43 PM »
The right way for the piston, yes.
But the barrels will not be worn at the top or the bottom, the piston rings don't go there when running.
Same as your picture, but 1/2 way into the barrels.
Offline murdock
Re: Cb 550 ss spain
« Reply #76 on: April 05, 2021, 07:27:37 PM »
In this photo you can now see the piston in the middle of its stroke, between its Upper Dead Center and its Lower Dead Center, the number 1 cylinder (to the left of the direction of travel) and its piston the GAP in the transverse direction is the one that can be seen, 0.10mm, 0.004 inch. ........ and if I try to put the smallest gauge I have in the longitudinal direction 0.04mm, .0015 does not fit
« Last Edit: April 05, 2021, 07:59:20 PM by murdock »
Re: Cb 550 ss spain
« Reply #77 on: April 05, 2021, 07:37:32 PM »
Very close,  but the position of the gauge needs to be 90 degrees from there.
Leave everything as it is in that picture BUT now move the gauge 1/4 around the piston and check there.
Offline murdock
Re: Cb 550 ss spain
« Reply #78 on: April 05, 2021, 07:56:51 PM »
Ok, from what I understand, instead of placing the gauge at 9 o'clock, I must place it at 12 o'clock, because what I said before, at 12 o'clock the smallest gauge I have does not fit (0.04 mm, .0015 inches)
Re: Cb 550 ss spain
« Reply #79 on: April 05, 2021, 08:17:21 PM »
Aah, I undersrand now.
That is how they would be machined originally to make the clearance correct.  If each piston in it's own barrel has the same measurement,  then it looks like it just needs new rings and light hone to build again.
Offline murdock
Re: Cb 550 ss spain
« Reply #80 on: April 05, 2021, 08:35:51 PM »
ok, thank you very much, I still need to check the other pistons, maybe tomorrow when I come back from work, I think the goggle translator is making things a bit difficult, I'll look for another one, the pistons look like the originals, after 65000 km (that indicates the speedometer) who knows !!!,  44 years and 7 previous owners seems to be a good machine, many thanks k2-k6, by the way, what rings could I buy?
Re: Cb 550 ss spain
« Reply #81 on: April 05, 2021, 09:18:09 PM »
Translation seems ok when it comes in English.
Just my understanding when looking at the picture. Another one to translate is "Babel fish" if you need one.
Hopefully someone else on here more involved in this size engine can suggest a supply of piston rings for you.
Re: Cb 550 ss spain
« Reply #82 on: April 05, 2021, 09:51:54 PM »
What does the bore actually measure? Is it 58.5mm
Offline murdock
Re: Cb 550 ss spain
« Reply #83 on: April 05, 2021, 10:23:39 PM »
Yes ! More or less
Offline murdock
Re: Cb 550 ss spain
« Reply #84 on: April 06, 2021, 06:56:16 AM »
I say more or less because I do not have an alexometer or an interior caliper, but measuring the skirt of the piston that seems within tolerance it is very close
Re: Cb 550 ss spain
« Reply #85 on: April 06, 2021, 07:23:58 AM »
58.5 is standard size for a 550 so you need standard rings and i wouldnt hone just take the glaze off with emery cloth or a "flap wheel"
Re: Cb 550 ss spain
« Reply #86 on: April 06, 2021, 08:47:00 AM »
Yes, about "glaze busting" but I was unsure how that would translate into Spanish language  :) "rompiendo el esmalte"
Re: Cb 550 ss spain
« Reply #87 on: April 06, 2021, 10:05:22 AM »
Me neither and really unsure about flap wheel but as i only speak lancastrian the rest of the country never mind the world is at a dissadvantage
Offline murdock
Re: Cb 550 ss spain
« Reply #88 on: April 06, 2021, 10:30:27 AM »
in Spanish it would be grinding well or griding tooth
Offline murdock
Re: Cb 550 ss spain
« Reply #89 on: April 06, 2021, 07:52:49 PM »
Hello, today I removed the other pistons, I measured them and they are all the same as the first, the rings are healthy but worn, they have a lot of gap, they were bought 6 years ago in cruizing image or whatever it is called, I think they are not very good, just about 2000 km, I suppose that due to the velocity stacs there should be other signs of wear, there is only a small friction in the piston 3 and 4, I will buy a kit of standard size imd rings, (or do you recommend others?) I hope they are of good quality, I have taken a photo of the tool in question, whatever its name is ,ha ha
