Author Topic: Final drive shaft  (Read 719 times)
Offline Lkp
Final drive shaft
« on: March 17, 2021, 06:54:05 PM »
Hi everyone..
I've got a f2 cases and an f1 final drive will this be ok to use?
Re: Final drive shaft
« Reply #1 on: March 17, 2021, 08:17:22 PM »
The F2 (and paired K7) both use a larger final drive bearing to, I think, all the other 750s. This because they use 630 chain size.
I don't think the F1 bearing will fit, can you try and compare the output shaft mounting to give more certainty?
Offline neilg
« Reply #2 on: March 21, 2021, 06:19:52 PM »
Because of the bigger bearing the engine sprocket is further away from the engine case by about 5mm, so chain alignment needs checking.
« Reply #3 on: March 21, 2021, 09:43:43 PM »
The 750F0, F1, F2 and K 7 all use the same bearings on the final drive shaft, but the shafts are different part numbers for the F2 and K7.
« Reply #4 on: March 21, 2021, 10:34:33 PM »
F1 andF2 have totally different sprocket retention method
Offline robvangulik
  • Honda Fourever
« Reply #5 on: March 21, 2021, 11:18:13 PM »
+1, F1 has the same method as the earlier K types with 2 m6 bolts in the sprocket, the F2 has the central retaining bolt.
