Author Topic: Hello from Shropshire UK  (Read 2816 times)
Offline 400 Cafe Racer
Re: Hello from Shropshire UK
« Reply #30 on: March 30, 2021, 06:53:10 PM »
Best vacuum gauges in my opinion, and most like original Honda, are Sealey and cost about £135 on ebay plus come with all adaptors. There are similar looking ones costing about £50 but the actual gauges are cheap and will not be as accurate.
Hi Bryan, thanks for your input on that, ;D I will have a look and add it to the list Also one other item I was loooking  for was a correctly sized Magnetic SUMP Drain Plug, if anyone can help please.
Dennis ;D
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #31 on: March 30, 2021, 07:45:40 PM »
Yet another please. ;)
FUEL PIPE CLIPS (spring fit)
Thanks Guys
« Reply #32 on: March 30, 2021, 08:38:32 PM »
Can anyone tell me the normal running oil pressure range please
« Reply #33 on: March 30, 2021, 08:51:27 PM »
Warning light extinguishes at approximately 15 psi and maximum pressure is capped at around 60 psi, estimated slightly as I think they may quote 59.something in manuals.
It'll dump excess out the relief valve to avoid risk to oil pump drive, as most engine arrangements do.
Flow is,  pickup, pump, floods filter housing, exits through filter element centre via main bolt to internal galleries.  Pressure relief also built in to filter bolt in case of filter blocking, so feed is maintained with unfiltered.
Barrel feed route to head has resistance in line to maintain crankshaft plain bearings in high pressure environment,  with cam etc at low pressure open bath type oiling and spray bars for wetting effectively.
« Reply #34 on: March 30, 2021, 09:24:52 PM »
Gee thanks K2-K6 thats great info  :) :)
I have been thinking about fitting an Oil pressure gauge and that gives me a good idea of the scale range to use. I'm thinking about picking up the feed from the pressure switch point but still retaining the switch, if I can find a suitable union/connection. I need to have a look what space is available tomorrow and the sizes of electrical senders.
Regards
« Reply #35 on: March 30, 2021, 11:18:01 PM »
When I fitted the oil guage to my CR750 Rep, I used a 'tee' off the oil pressure switch pickup point - its a few years since I did it so can't remember gallery thread for the 'tee' but think I searched the US SOHC site. Then worked back from the guage for fittings/pipe
Online Bryanj
« Reply #36 on: March 30, 2021, 11:57:42 PM »
On a 400 there is not room to put anything extra where the pressure switch is(on oil pump under sprocket cover) so you need to drill and tap the screwed in plug under the points cover, just so happens i took one out of a 500 engine on Sunday you can have for post
« Reply #37 on: March 31, 2021, 01:01:48 AM »
Nice machines. 👍
Please tell me that you're going to improve the 400 rear brake pedal. I couldn't live with that Allen bolt sticking out! 😣
Hi taysidedragon, well spotted. ;) Yes its on the " to do" list, but at least its solid for now until i can source a nice replacement. Any suggestions from your experience please
I would try and get a longer knurled bar made to replace the pedal that's too short.
For carb balancing I use the Morgan Carbtune set. Well damped and accurate.
« Reply #38 on: March 31, 2021, 08:24:11 AM »
Hi Bryan, thank you for your info and help, thats very kind of you. I will PM you and make some arrangements.  :)
« Reply #39 on: March 31, 2021, 08:51:37 AM »
Nice machines. 👍
Many thanks for the info Gareth.  :)
I will have a look at the Morgan set. The pedal if on my “to do” list for attention.
Cheers  ;D
« Reply #40 on: March 31, 2021, 09:00:50 AM »
Many thanks Phil  :)
I plan to have a good look around the space and clearance situation today, both near the o/p switch and the points cover. Plus placement of the gauge, possibly opposite the A/F ratio gauge.
Cheers  ;D
« Reply #41 on: March 31, 2021, 10:10:48 PM »
On the 400/4, can anyone confirm the oil pressure light switch and oil pump casing thread size please ? :)
