Author Topic: CV carbs - how do they work?  (Read 3623 times)
Offline pae
    • Phil's CB650 pages
« on: December 28, 2009, 07:34:52 PM »
Think they're called CV - they're the vacuum type carbs fitted to a '85 Yam XJ600. As the Yam forum continues to be pretty useless with answers I thought someone here may have experience of these type of carbs as I've never played with them before, being used to a cable opening the slider, not a vacuum.
I don't have an airbox for my project and wonder if not having one fitted will affect the carb vacuum. I know it won't run great but just want to fire it up briefly, but will it run at all like this?
I've never worked with vacuum carbs before - what lifts the sliders up so I can squirt some easy-start in to the throats whilst it's turning over? Presumably it's a vacuum in the top of the carb bodies that lifts the sliders, but where does the vacuum come from? There are no hoses that connect up to the carb tops as far as I can see.
regards, Phil
Offline matthewmosse
Re: CV carbs - how do they work?
« Reply #1 on: December 28, 2009, 09:14:01 PM »
I think it works by the air pressure difference created by the airflow thru the carb - things that go wrong, is the diaphrams can split / perish. I'm not a great fan of them myself but keep it all as is because they cann't be all that bad compared to trying to fit something else. In theory they should give better fuel economy and they should work ok with k&n s or probably with no filter. Have some on my bmw airheads. If the economy's worse with slide carbs I'm glad of the difference as the bike's not that economical.
« Reply #2 on: December 28, 2009, 09:16:22 PM »
2022 Tiger Sport 660
« Reply #3 on: December 29, 2009, 10:08:21 AM »
That's a great link, thanks Steve, same bookmarked
Den
Offline pae
« Reply #4 on: December 29, 2009, 03:12:04 PM »
Thanks Steve, good link. Should all be OK then, will give it another go tomorrow.
Offline pae
« Reply #5 on: December 31, 2009, 03:13:42 PM »
Well it runs, very briefly, on easy-start squirted in the carbs, but dies again straight away. Suggests the fuel isn't getting through I guess???
BTW, should you be able to see the sliders lifting on a relatively small vacuum (like turning the engine over on the starter) as none of them do but I don't know if there's enough airflow to move them in that situation.
Think I'll pull the carbs off for a clean through and check-over.
Offline dave400
« Reply #6 on: December 31, 2009, 04:18:02 PM »
I don't now a thing about thoses type of carbs, stick at it I'm sure it will fire up in the end, I hated my type of carbs after a rebuild also!
Good luck with the vote on the other site and Happy New Year.
Dave
Offline Yoshi823
  • Biker to the bone...
« Reply #7 on: January 12, 2010, 06:39:06 PM »
The carb slides don't lift at tickover, and don't up to a certain number of revs. I would look for a leak in the inlet rubbers as these would cause the engine to see too weak a mixture after you let off the choke/enrichener.
When you rebuild the carbs, ensure that the diaphragms are seated correctly by lifting the slide, then push the slide spring down together with the carb top, making sure that the small 'o' ring is in place in the recess as you bolt/screw the top in place.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
