Author Topic: Crankshaft oil seal fitting  (Read 680 times)
« on: April 17, 2021, 11:05:54 AM »
Hi All,
A quick question........................
I ordered a complete seal kit for the Z400J and this included the two crankshaft oil seals.
I fitted the seals and all appeared to be fine, crackshaft turned, the lip was properly in place so I bolted the two crankcase halves together.  Skip forward a couple of hours and the tidy up and I noticed the old crankshaft seals had a ridge around the outside of the seal (as do Honda seals) to fit inside a machined groove in the crankcases. The new seals didn't have the ridge.
Question is do you think the new seals are OK? They are from Wemoto and they are a reputable company. The seals are Japan made. I really dont want to take thje engine apart but then again I dont want the new seals to blow under pressure.
What does the forum think....?
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Lynx
  • Repair & Despair Under One Roof
Re: Crankshaft oil seal fitting
« Reply #1 on: April 17, 2021, 11:15:40 AM »
As long as your engine breather is not blocked, they shouldn't be under pressure and so, they should be fine!
Sent from my HTC Desire 530 using Tapatalk
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
« Reply #2 on: April 17, 2021, 11:51:23 AM »
Agreed
« Reply #3 on: April 17, 2021, 11:54:28 AM »
Phew.....😨. Thanks guys👍. I can sleep tonight!
1976 Honda 400/4
