Author Topic: Plastic Coated Frame  (Read 783 times)
Offline Deano400
« on: April 24, 2021, 02:18:54 PM »
I'm sure in the past there has been a thread relating to plastic coated frames. I have searched for the thread without any joy.
There are a couple of things I'd like to get some advice on.
I think the bike I have just started has a plastic coated frame. Having never seen a plastic coated frame before is there a way I can tell if it's plastic or some sort of paint?
If it is plastic coated, will blasting remove it? If not, can anyone advise on the best method of removal?
John
Re: Plastic Coated Frame
« Reply #1 on: April 24, 2021, 05:03:42 PM »
Never heard of plastic but powder coat "plasticises" with the heat used to bake it
Offline Deano400
« Reply #2 on: April 24, 2021, 05:28:30 PM »
Cheers Bryan.
Offline martin_uk
« Reply #3 on: April 26, 2021, 01:51:56 PM »
I had a Norton Commando that PO had frame plastic coated.
Sounds like a good idea, but started to seperate and water  got in between.
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
« Reply #4 on: April 26, 2021, 03:39:10 PM »
All the brackets on my Rickman (Hondastyle) fairing (see avatar) were plastic coated.
After a year or two with the vibration and the UV breaking down the plastic, it had cracked and the underlying steel had rusted pushing more of the plastic apart.
I think it was a solution looking for a problem. Probably cheaper too .
2022 Tiger Sport 660
« Reply #5 on: April 26, 2021, 05:16:05 PM »
You need to find someone with a Pyrolitic burn-off oven to burn off the plastic coating and turn to ash. As long as the whole frame is heated/cooled in a uniform manner there will be no warping/damage. Just don't be tempted to 'throw it in a bonfire' as someone once suggested I try as an alternative option...
Offline Deano400
« Reply #6 on: April 27, 2021, 09:45:14 PM »
Thanks JamesH.
