Author Topic: What size / colour Plasigauge do I need.  (Read 500 times)
« on: April 24, 2021, 03:01:19 PM »
All this colour coding it's spreading everywhere it was bad enought working out what size shells I need  -not used Plasigauge in decades my memory was of it being white - so for a 400/4 crank what colour do I use on the mains please - Red Grey or Green?
Secondly will it be sufficient to just secure the main (10) crank case bolts above the crank to get a reliable reading?
Re: What size / colour Plasigauge do I need.
« Reply #1 on: April 24, 2021, 03:04:51 PM »
Definitely Green
Ask Bryan about the bolts but I just torque up the main bolts.
« Reply #2 on: April 24, 2021, 03:11:58 PM »
Definitely Green
Thanks for that - then I measure the width of the squash - this then gives me via a table a clearance based on the ratio of the original size to the squash the clearance is that the idea?
« Reply #3 on: April 24, 2021, 03:39:09 PM »
The Plastigage is a filament that squashes between the crank journal and the shell when the cases are bolted together. It deforms to a permanent width film, the width of which is compared with the scale on the Plastigage packaging and is representative of the shell-to -journal clearance.
« Reply #4 on: April 24, 2021, 05:02:27 PM »
Yes just the main bolts
« Reply #5 on: April 24, 2021, 09:29:14 PM »
Okay got it thanks Ash.
