Author Topic: Rubber Pucks  (Read 638 times)
Rubber Pucks
« on: April 25, 2021, 07:27:53 AM »
There is no doubt in my mind that if Honda engineers thought that the rubber pucks weren’t needed they would not have fitted them between cooling fins. The thing is some engines have them and some very similar engines don’t. So my question is it noise/vibration dampening? Has anybody actually tried to run without them or even tested with and then without. Or should I accept that these are necessary.
1978 Honda CB550K3.
Re: Rubber Pucks
« Reply #1 on: April 25, 2021, 08:28:13 AM »
With out fin rubbers in the fins ring and can crack at the fin rubber location holes. If you need a full pack contact Julie as i think i have some in stock  ;)
Re: Rubber Pucks
« Reply #2 on: April 25, 2021, 08:55:20 AM »
Brilliant Trigger, that more than justifies replacing them! I will contact Julie.
1978 Honda CB550K3.
