Author Topic: Float bowl adjustment  (Read 571 times)
Offline Athame57
    • SeaWitch Artist
« on: May 01, 2021, 04:11:58 PM »
The float bowls in the carburetor third from left is sitting lower than the others and there is no springiness to them, what to do about it and what trouble could this be causing? I can't work out how to change anything. ::)
1978 CB400F2 called Elen.
Re: Float bowl adjustment
« Reply #1 on: May 01, 2021, 04:25:33 PM »
Your float height needs adjusting on the tang George. Follow this:-
Edit, is there actually a float valve under the tang, that float does look very, very low?
http://www.sohc.co.uk/index.php/topic,23233.0.html
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: May 01, 2021, 04:53:07 PM »
Hi Julie, yes I took the thing of there is that thing underneath with the spring stud sticking out...I'll go pour over your link now.... ;)
« Last Edit: May 01, 2021, 05:04:45 PM by Athame57 »
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: May 02, 2021, 07:43:53 PM »
I can’t see the tang, has it broken off?
You had me worried there, no it's still there, just that the flash has made it come up very light.
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: May 02, 2021, 07:46:10 PM »
Before I go any further, I've been thinking how to best clean them while they are open, there is this film of dry dusty sort of blemishing. Any suggestions?
« Reply #5 on: May 03, 2021, 01:03:23 PM »
I stripped mine right down then had my BiL Ultrasound clean the dismantled  parts.
« Last Edit: May 03, 2021, 04:57:41 PM by Macabethiele (Ted) »
