Author Topic: CB400 4 rebuild Where do I start  (Read 3765 times)
Offline stuartb
    • My Website, buy as many as you like
« on: January 18, 2010, 01:07:25 AM »
Hi, I am in process of starting rebuild on a 1978 400/4..its in poor order cosmetically, but otherwise ran fine till about 5 years ago, hasn't turned a wheel since..  I expect all the usual probs.  However, where do I start...  Do I pull apart, or try and get it running and assess whats required.  I rebuilt a CG125 around 25 years ago and have a mech/eng back ground so pretty handy with the tools..
Any advice would be great.
Thanks  Stuart
02 Blade, Blue and White..  Grotty CB 400/4 and a Grotty 1980 wing
Re: CB400 4 rebuild Where do I start
« Reply #1 on: January 18, 2010, 05:29:32 AM »
Get it running and maybe MOT'd first then start tydying up
« Reply #2 on: January 18, 2010, 07:26:46 AM »
I'm with Bryan.
Get it running, sort the brakes etc, MOT and ride it around for a while (doesn't matter how ratty it looks).
When (if?) you decide it's the bike for you, then set off on the refurb route (expect to spend
2022 Tiger Sport 660
Offline matthewmosse
« Reply #3 on: January 18, 2010, 08:04:44 AM »
I'd also go with getting it running, that gives you the confidence to know what needs attention so you don't either refurbish something that's dead - frustrating, or refurbish/replace something that was fine anyway - expensive.
« Reply #4 on: January 18, 2010, 01:24:15 PM »
I would also go down the get it running route at least then you will know what it is that you have.
Den
Offline stuartb
« Reply #5 on: January 20, 2010, 09:39:34 PM »
Excellent guys TYVM...Ill keep you all informed...Do you know of anyone who is selling good body parts  tank, panels etc
Stuart
Offline UK Pete
« Reply #6 on: January 20, 2010, 10:12:54 PM »
If you do start taking it apart get as many photos as you can. they always come in usefull plus every one loves to see progress in pictures on the forums, i would suggest before you go too far cost up the bits you think you are going to need, i recently started a rebuild/ restoration of a 750, and it stands me in at least 3 times what i wanted to spend already.
Pete
Offline stuartb
« Reply #7 on: January 21, 2010, 11:18:03 PM »
Sound advice again pete, thanks for that.
Stuart
